foglights don't work - Saturn Sky Forums: Saturn Sky Forum
 2Likes
post #1 of 16 (permalink) Old 07-14-2019, 08:23 PM Thread Starter
Quoted: 2 Post(s)
cluster indicates that they are on when I engage the switch . They don't come on. stalk is in low beam and bulbs appear to be good. relay in the engine compartment fuse box appears to be good as well because I swapped it with another relay with an identical pn#. Any one with any suggestion. I cant find a repair manual by Haynes or Chilton.
Appreciate any help
Cosmo is offline
post #2 of 16 (permalink) Old 07-14-2019, 10:41 PM
You didn't mention the fuse. #53 , 15A
JohnWR is online now
post #3 of 16 (permalink) Old 07-14-2019, 11:49 PM
Quoted: 920 Post(s)
Does the light on the switch illuminate when u engage the button. Just narrowing down some questions here.
marlboromike is offline
post #4 of 16 (permalink) Old 07-15-2019, 08:56 AM
Ghost-Sky's Avatar
Quoted: 6 Post(s)
Do a little research on this site, this was disgust. I believe the problem could be the switch.
"The Sky's The Limit"
jshines likes this.
(Ghost-Sky)
Ghost-Sky is offline
post #5 of 16 (permalink) Old 07-15-2019, 10:11 AM
If the indicator light is on how can it be the switch?
post #6 of 16 (permalink) Old 07-15-2019, 11:02 AM
LAC Sky's Avatar
Quoted: 134 Post(s)
Good reminder for me to go check mine.. to see if indeed they do work upon request. Haven't checked them this year.
Once a year usage. It could be the switch if it has power/ground? DIC says one thing to the owners eye, but... things are
different when electrical gremlins appear out of no where.
Ground problem? Power to the switch/relay/fuse/socket, bulb is ok, but no light? Wiring connection in the loom gone bad?
Corrosion or bad plug/other that could have gone bad. Meter check? How often do you as owner use them?
Once a week, month, or like me.. once a year?
Never really looked that closely at mine, rarely use the things, but it IS nice to know they do work,
if I should need them to perform their job as intended by the designers of the Kappa.
Been crazy weather here(nice now though for the moment ), just before the 4th of July.
Mini tornado sort of. Spent the better part of last week cleaning up a downed 40 ft. tree about
50 yds. away from my car, other tree branches off the porch roof/property.
Went for good cruise last Friday, Lunch run, then to High Rock glorious day for it. Perfect.
Felt good after the chainsaw hell of the last few hot days here. Prepping my IC intake bumper for Go-Pro "street level view"
for upcoming video! Gonna try a rearward facing view between the seats just for something different to dash cam for the video collection too. Why not?
* Conowingo Dam Run 2019. 204 miles of smiles for me. 7 hours. Go-Pro videos. $37.00 bills. Well worth it.
Keep checking off the list of what if I try this next here: Electrical chase for a problem is always fun for the owner/operator. Not.
Stay persistent in your pursuit. I know it's just the fog lights here but it is the principle of the thing here. I hate it when something
is not to my liking no matter how small the issues might be. Fix it or Forget it?
Frustration and money spent on solving these minor problems is part of the automotive culture.
Comes with the territory of ownership. Be lucky it's the fog lights or lack there of here. It could have been
something far more serious with greater deep pain to your checkbook/credit card.
LAC Sky is offline
post #7 of 16 (permalink) Old 07-15-2019, 12:27 PM
Ghost-Sky's Avatar
Quoted: 6 Post(s)
I'm just going by what others have found.
(Ghost-Sky)
post #8 of 16 (permalink) Old 07-15-2019, 01:04 PM Thread Starter
Quoted: 2 Post(s)
Fuse checks ok
Cosmo is offline
post #9 of 16 (permalink) Old 07-15-2019, 01:06 PM Thread Starter
Quoted: 2 Post(s)
light in cluster comes on
Cosmo is offline
post #10 of 16 (permalink) Old 07-15-2019, 01:10 PM Thread Starter
Quoted: 2 Post(s)
Foght lights
Fuse is ok . I purchased a switch and it has 4 poles . Im going to assume that one feeds the cluster light. It doesn't appear to be too challenging to replace it , so I will start there.
Thanks
Cosmo is offline
post #11 of 16 (permalink) Old 07-15-2019, 01:16 PM
Quoted: 476 Post(s)
Thanks
Nope. The switch has two of the contacts, the others are for the backlight.
Like John said if your indicator light comes on in the dash, the switch is working.
TomatoSoup is offline
post #12 of 16 (permalink) Old 07-15-2019, 06:03 PM
I would have someone turn them on and off while I listened for the relay to click. Or turn them on and unplug the relay and see if it clicks when plugging it back in.
Some of the relays can be plugged in backwards, so you might check for that.
post #13 of 16 (permalink) Old 07-15-2019, 08:59 PM
Quoted: 476 Post(s)
I agree with the 'click' check idea.
But all our relays are either keyed insertion, or symmetrical and it doesn't matter which way they go in.
Rob the Elder likes this.
post #14 of 16 (permalink) Old 07-15-2019, 09:26 PM
Odd. My DRLs weren't working, I reversed the relay, and then they did. I wonder what the problem really was.
post #15 of 16 (permalink) Old 07-16-2019, 09:56 AM
Quoted: 476 Post(s)
Maybe just a bad connection, or the vibration when removing fixed it?
I know for sure the DRL relays are symmetrical - coil wires on diagonal pins and contacts on the opposite diagonal. See: https://www.solsticeforum.com/forum/...d-users-73671/.
(Note: AFTER that mod, the relays were no longer symmetrical )
