New EU-style battery - Saturn Sky Forums: Saturn Sky Forum
 3Likes
  • 1 Post By davhamm
  • 1 Post By mstrjon32
post #1 of 11 (permalink) Old 04-17-2019, 04:14 AM Thread Starter
Kjelle69's Avatar
Quoted: 43 Post(s)
I went for the Varta P.nr. '563 401 061 316 2', since I have some contacts that recommended this type.
Had to bend one of the tabs a little bit since the base is a bit longer otherwise the fit was perfect.
Also freschened up the baseplate with durable paint and cleaned and torqued the ground point behind the battery.
Name:	Opel Batteri.jpg
ID:	104831   Click image for larger version
Name:	Opel Batteri2.jpg
Kjelle69 is offline
post #2 of 11 (permalink) Old 04-17-2019, 03:36 PM
It is interesting that you had to bend a tab because the battery is too long. The batteries recommended by Varta are both longer than the one you have.
JohnWR is online now
post #3 of 11 (permalink) Old 04-17-2019, 05:07 PM
davhamm's Avatar
Quoted: 460 Post(s)
Please explain EU-style.
I am a GM Engineer.
2009 HYDRO REDLINE AUTO
davhamm is offline
post #4 of 11 (permalink) Old 04-17-2019, 06:00 PM
I assume that it means that it was built to European dimensions, but it could be that it is silver instead of black.
post #5 of 11 (permalink) Old 04-18-2019, 09:00 AM Thread Starter
Kjelle69's Avatar
Quoted: 43 Post(s)
With "EU-Style" I meant that it seems that there are different standards in sizing of the batteries. (I am not 100% sure that it is but that's my qualified assumption)
I have tried to find a battery that conforms with the AC Delco "86" size here in Sweden. But it seems to be impossible. (Unless I order an AC Delco battery, but they are very expensive here).
A contact in Germany had success with this specific Varta battery with the size: L:242mm W:175mm H190mm.
The very "Base" is slightly longer than 242mm because there is a wedge on the battery there, because of this I had to bend the tab a little bit to make it fit properly.
(I still saved a small part that kee4ps the battery in place and now after I bent the tab the battery slides in much more easily)
Kjelle69 is offline
post #6 of 11 (permalink) Old 04-18-2019, 10:13 AM
davhamm's Avatar
Quoted: 460 Post(s)
Ok, I thought maybe there was some new battery tech or something that the EU was requiring,
Kjelle69 likes this.
I am a GM Engineer.
davhamm is offline
post #7 of 11 (permalink) Old 04-18-2019, 02:45 PM
Quoted: 137 Post(s)
I was able to find a replacement battery in Germany that nearly matched the original specifications, though it's not from a name-brand manufacturer. I did have to remove the inner bracket behind the fender in order to fit it as it was a bit too tall, but it just fits with everything back in place.
mstrjon32 is offline
post #8 of 11 (permalink) Old 04-18-2019, 05:31 PM
skersfan's Avatar
Quoted: 799 Post(s)
I would contact an Opel dealer to see what they recommend, but it sounds like you have the problem solved. They most likely require a Delco any way.
skersfan is offline
post #9 of 11 (permalink) Old 04-19-2019, 12:13 AM
Quoted: 137 Post(s)
No doubt the Opel dealer can provide the correct battery, but batteries from the dealer are usually . On the other hand, they do sell the passenger presence sensor for about 80.
post #10 of 11 (permalink) Old 04-19-2019, 12:14 AM
Quoted: 137 Post(s)
Also, Kjelle69, it's time to wash that engine bay down!
post #11 of 11 (permalink) Old 04-20-2019, 05:03 PM Thread Starter
Kjelle69's Avatar
Quoted: 43 Post(s)
Yes, I will do that now when the sun have begun to shine and the snow are melting away :-)
Kjelle69 is offline
