Please Help Me Misfire Detected - Saturn Sky Forums: Saturn Sky Forum
 2Likes
post #1 of 50 (permalink) Old 04-12-2016, 09:18 AM Thread Starter
gtturkey's Avatar
Quoted: 3 Post(s)
Hi All
I live in Turkey.My Car is 2009 Model and 34.000 km(21.000 mil) Ecu Map original. Total 10 Opel GT roadsters(Saturn SKY Redline) in Turkey No body know anything.Thank you in advance for your advice and help
Generaly Ihave not a problem but sometimes my engine light is flasing , sometimes light on. When I checking our elm327 Obd , it find the Misfire detected 301,302,303,304 not all times all codes , sometimes 301,302 ,sometimes 301,302,303 , sometimes all
I know 2-3 solutions for misfire detected
1 Solutions I changed ignition coil and change gasoline station but the same situation.
2 Solutions need to Change ignition coil.When I searching ignition coil I find below product.You can see item description they write "Repair to misfire"
When I seen this descripton this problem is cronichal problem for oem ignition coils ?
What you think and what do you recommend?
I am sory for my english.I hope understand me
Thank You
gtturkey is offline
post #2 of 50 (permalink) Old 04-12-2016, 10:40 AM
miller11386's Avatar
Quoted: 17 Post(s)
The first thing I would do is look for a leak anywhere after the MAF sensor. It sounds like you may have a cracked IC or maybe a torn connection causing issues.
The easiest way Ive found is to spray starting fluid at joints and listen to engine RPM. If you have the means, a boost leak check would be the easiest way, but not many kappa folks have the time or need to make a setup for this.
Goodluck!
miller11386 is offline
post #3 of 50 (permalink) Old 04-12-2016, 09:49 PM
Elff's Avatar
Quoted: 263 Post(s)
It could also be coking on the intake valves.
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #4 of 50 (permalink) Old 04-13-2016, 11:27 AM Thread Starter
gtturkey's Avatar
Quoted: 3 Post(s)
Thank you for advice ..I wil check that.
Does anyone have any other suggestions?
gtturkey is offline
post #5 of 50 (permalink) Old 04-13-2016, 03:01 PM
Quoted: 1760 Post(s)
When you're getting them like that, the advice you have is the best. I have a misfire that keeps coming up on cyl. 1 and it has been hard to track down. Yours sounds like it is on all cylinders at some point in time. Like others have said, look for leaks. Chances are it's something beyond spark.
post #6 of 50 (permalink) Old 04-28-2016, 03:56 AM
Napi's Avatar
Quoted: 3 Post(s)
What type of petrol are you using?
Many Germans experience similar problems when using the "crappy 95 octane petrol".
(keep in mind, that turkey and europe use the RON, reasearch octane number, NOT the AON, average octane number, meaning our "95 octane petrol" is comparable to your reguar petrol, having 87,5 octane or something. Our "98 Plus" is comparable to your premium, while the new stuff (Aral ultimate 102 f.e.) would have something around 95 octane in "your" system.)
You MUST AT LEAST use Super Plus 98.
Do you have a chance to get higher quality petrol? BP Ultimate, Shell V-Power Racing or something else?
Egal wie dicht du bist; Goethe war Dichter!
Napi is offline
post #7 of 50 (permalink) Old 04-28-2016, 12:16 PM
SARBlade's Avatar
The cars are very susceptible to ground issues, check the negative on the battery, the ground wire off the engine to frame, also, if the battery is showing signs of being old, a new one clears up alot of the electrical bugs. These are the easy fixes I checked first and haven't had a 0301 code in along time.
2008 Sky Redline
Tarnished Silver Metallic
Trifecta Tuned
10mm 6061T Tunnel Brace
Eyelids
Seat Heaters
Universal Garage Remote
SARBlade is offline
post #8 of 50 (permalink) Old 04-28-2016, 01:48 PM
SARBlade, did you have a P0300 code (random misfire) or a P0301 code (misfire in Cylinder 1)? I ask because I'd think a ground or battery issue wouldn't just trip a P0301 code...a P0300 sure but why would it only cause cylinder 1 to misfire?
post #9 of 50 (permalink) Old 05-17-2016, 11:22 AM Thread Starter
gtturkey's Avatar
Quoted: 3 Post(s)
in Turkey Onlu 95 octane and 95+ (ultimate-vpower etc) I use + series.But I read Turkish user manual they write"95 octane"
gtturkey is offline
post #10 of 50 (permalink) Old 05-17-2016, 11:31 AM Thread Starter
gtturkey's Avatar
Quoted: 3 Post(s)
My Car Model 2009 and now it has Original Acdelco battery I know long time for battery 7 years but normaly battery is good working.
Last time clear battery + side and long time No live misfire but after some times to have problem
You think my battery is broke ?
SARBlade, did you have a P0300 code (random misfire) or a P0300 code (misfire in Cylinder 1)? I ask because I'd think a ground or battery issue wouldn't just trip a P0301 code...a P0300 sure but why would it only cause cylinder 1 to misfire?
My error code almost all clyndir misfrie Not only 1
gtturkey is offline
post #11 of 50 (permalink) Old 05-17-2016, 12:16 PM
Napi's Avatar
Quoted: 3 Post(s)
Try an octane booster.
Despite the Manual saying 95 will fit, it doesn't.
Dozens of Germans experienced the exact same problem when driving with 95. As soon as they switched to 98, the problem was solved and the misfire (plus rough start on some cars) was gone after some hundred kilometers.
This is one of the most common and known issues with the Engines in Germany. Even the German Opel vendors/fgarages changed their advises to "98+" despite the fact that the German Manuals also say "95".
Napi is offline
post #12 of 50 (permalink) Old 05-17-2016, 12:51 PM
Dang Napi, thanks for that info. I'd think that since the US cars are designed to run on 91 octane that 95 would have been more than enough. Though, IIRC, I think Europe uses a different octane rating system than the US and 95 in Europe isn't as high of an octane rating as 95 would be in the U.S. Can't remember the approximate conversion though.
post #13 of 50 (permalink) Old 05-17-2016, 01:21 PM
SARBlade's Avatar
Well my code was always p0301. I switched #1 and #2 coils to see if problem moved. It didn't. So could and wires not issue. Searched web, said grounds may cause this. Cleaned grounds. This worked but got a couple of erroneous codes. Changed battery all is good!
SARBlade is offline
post #14 of 50 (permalink) Old 05-17-2016, 01:24 PM
Hmmmm...makes me wonder if I need to check my grounds as I have the same issue and moving around coils didn't help.
post #15 of 50 (permalink) Old 05-23-2016, 03:47 PM
Quoted: 139 Post(s)
95 in Germany ("Super") would be 90 in the US system, and 98 (commonly referred to as "Super Plus" would be 93. I run the "Super Plus" in my Sky and it runs just fine, and have tried some of the 100+ octane fuels and didn't notice any difference--certainly not worth the extra price.
I run Super E10 (95 with 10% Ethanol) in my turbo Saab 2.0 and it runs just fine.
mstrjon32 is online now
