Sky vs Solstice Door Panels - Saturn Sky Forums: Saturn Sky Forum
 1Likes
post #1 of 17 (permalink) Old 03-19-2018, 05:46 PM Thread Starter
Quoted: 13 Post(s)
So "nicer" weather has finally hit Iowa, at least temporarily. I decided to clean up the Sky and get her ready for the year, plus take her in for the airbag recall and a new battery and remember how much my wife wants to get rid of the red and black interior (besides its not in the best condition) so I decided to look up what all parts were still available.
I was checking out the door panels specifically first and noticed that for an 09 Sky there is only a RIGHT door trim panel available, however for an 09 Solstice there is only a LEFT door trim panel available (of course I may not be looking at the best source but links for reference).
https://www.gmpartsdirect.com/auto-p...trim-door-scat
Best I can find on google these door trim panels look the same between cars, does anyone know if they are interchangeable? They are different part numbers for LEFT Sky and LEFT Solstice (right as well, etc) but so are all the other parts they I would think would be shared. Being heavily involved with product development and engineering at a manufacturing company I know our numbering scheme is terrible and we duplicate information all of the place. Any help would be appreciated.
'09 Ruby Red Redline
AndersonClan is offline
post #2 of 17 (permalink) Old 03-19-2018, 05:57 PM
Junior Member
Quoted: 529 Post(s)
They will fit either car, but they definitely LOOK different - you wouldn't want to mix and match. Plus the Solstice one does not exactly match where it meets the Sky dash (AFAIK - though I could be wrong).
Pics of the Sky door followed by the Solstice:
TomatoSoup is offline
post #3 of 17 (permalink) Old 03-20-2018, 09:27 AM
Quoted: 181 Post(s)
I have not done the swap but have read on the Solstice forum that they are a direct replacement. I have had the center panel out of both cars and they ARE interchangeable. The only difference according to reports is the wiring is different between the two cars. When installing a Sky panel on a Solstice, I think I read that they needed to lengthen the Sol cable to fit the Sky connectors. Based on that, I suspect that if you install a Sol panel in a Sky car it will fit.
I could test this theory but it would involve taking apart both cars and I am working to get them both back together for Nationals so . . . .. sorry.
Rob the Elder is offline
post #4 of 17 (permalink) Old 03-20-2018, 10:03 AM
Quoted: 51 Post(s)
Sine your car is a 09 you will have to replace with 09 panels or at least change out the window switches. The plug for the window switches are different on the 07 and 08 models. If you look at a 08 driver side window and mirror switch you will notice the buttons are reversed for the mirror adjustment the 09 is different.
Hoosier GXP is offline
post #5 of 17 (permalink) Old 03-20-2018, 10:50 AM Thread Starter
Quoted: 13 Post(s)
Thanks for all the good information, looks like I will end up just stripping the panel down and recovering the leather.
post #6 of 17 (permalink) Old 03-20-2018, 11:20 AM
Quoted: 1025 Post(s)
Might as well post this....in my possession is a DISCONTINUED passenger side black door panel for a 06 Sky build...no door switch...any interested buyers out there?
marlboromike is offline
post #7 of 17 (permalink) Old 03-20-2018, 12:34 PM
Quoted: 1822 Post(s)
I would either try Car-parts.com and see if you can find some used ones close by OR see what an interior shop would charge to recover them. I'm getting both seats and the door panels redone for relatively cheap.
Robotech is online now
post #8 of 17 (permalink) Old 03-20-2018, 02:16 PM
How about going to PLAN B...getting rid of the WIFE?
post #9 of 17 (permalink) Old 03-20-2018, 05:37 PM
skersfan's Avatar
Quoted: 860 Post(s)
MM for hire?
skersfan is offline
post #10 of 17 (permalink) Old 03-20-2018, 09:00 PM
Originally Posted by skersfan View Post
MM for hire?
I don't come cheap...I wear the Union Label.
post #11 of 17 (permalink) Old 03-20-2018, 09:34 PM
44thSKY's Avatar
Quoted: 392 Post(s)
Now just a g-damn minute, we like Patti!!
44thSKY is offline
post #12 of 17 (permalink) Old 02-22-2019, 09:56 AM
Junior Member
mtdjohn2018's Avatar
Quoted: 41 Post(s)
I'm getting my inserts recovered next week at a local Upholstery shop for $125. I am using Marine grade vinyl instead of leather though. You will find that putting the inserts back in to be a bit challenging since they wern't designed to be removed but I came up with a clip and screw to securely remount them. I'm still kicking around the idea to have the complete door panel covered in black since I have some fading going on. The problem is, once you recover the door, where do you stop? I really don't want to reupholster the whole inside! Any thoughts on how you think it would look to just do the door panels? Has any member done just those parts and left all of the other plastic panels original?
mtdjohn2018 is offline
post #13 of 17 (permalink) Old 02-22-2019, 01:23 PM
My door panels were redone like you are doing yours...in Marine grade vinyl. Seats too. I think they turned out great.
ID:	104263   Click image for larger version
ID:	104265   Click image for larger version
ID:	104267   Click image for larger version
marlboromike likes this.
post #14 of 17 (permalink) Old 02-22-2019, 02:29 PM
Do not test the theory Rob...I changed the door panel for the Solstice....definitely the wiring is shorter on the Solstice on the driver's side....but if u pull hard enough on the harness (I got lucky it did not break)...u can make it fit the Sky door panel. That was Dr. Golfs Solstice.
post #15 of 17 (permalink) Old 02-22-2019, 03:03 PM
Junior Member
Quoted: 41 Post(s)
Robotec,
Your interior looks fantastic! I can't tell from the photos but did you recover the complete door panel or just the inserts?
