top wont close - Saturn Sky Forums: Saturn Sky Forum
post #1 of 29 (permalink) Old 05-22-2011, 10:46 PM Thread Starter
top wont close
I went to put up my top today and it stopped a few inches from close. It appears something has happened that causes the grey flap not to come up along with the top. So the top stops as it hits the grey flap.
Has anyone ever experienced this? I'm hoping something just came loose and can be placed back.
AnonNomis is offline
post #2 of 29 (permalink) Old 05-23-2011, 12:04 AM
I'm not clear what you mean by "gray flap"?
Maybe photos will help us help you?
Jim
One can not hide from karma!
JimVonBaden is offline
post #3 of 29 (permalink) Old 05-23-2011, 01:23 AM Thread Starter
Here are two pictures while the top is being moved up. One grey flap moves up with the top like it should and the other stays down.
ID:	40524   Click image for larger version
post #4 of 29 (permalink) Old 05-23-2011, 01:24 AM
DaveOC's Avatar
Quoted: 9 Post(s)
JVB: The flaps in the tulip panel where the top supports go when the top is up.
There are cables attached to each flap which pull them open when the top is pulled up. They probably have come loose, and need to be reattached.
There are little plastic fittings that attach the cables and these may be broken or missing.
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #5 of 29 (permalink) Old 05-23-2011, 01:58 AM
Quoted: 181 Post(s)
There is a thread from last summer on the Sol forum about this. It has part number for the clip.
Rob the Elder is offline
post #6 of 29 (permalink) Old 05-23-2011, 02:44 AM Thread Starter
I confirmed what you said. It looks like part of the cable has come off of the clip that holds it. I placed it back on and it works but it pops back off when the top goes all the way up. It doesn't look broken compared to the opposite side. Should I glue it back on there?
I couldn't find the thread in the solstice forum. Can anyone link me or do you remember if that clip was the part they replaced?
post #7 of 29 (permalink) Old 05-23-2011, 03:09 AM Thread Starter
I forgot to post the pic.
post #8 of 29 (permalink) Old 05-23-2011, 08:43 AM
Yeah, I get it now. From my tulip pannel replacement photos:
Jim
post #9 of 29 (permalink) Old 05-23-2011, 11:46 AM
Clip part# 15290793
Both sides same part in red. One just goes in upside down.
2nd American Legends 2013
lllfly is offline
post #10 of 29 (permalink) Old 05-23-2011, 12:35 PM
MidniteBlues's Avatar
Quoted: 11 Post(s)
Several thread to chose from in this forum...
See my post #8
https://www.skyroadster.com/forums/f5...p-doors-36506/
More info here also
https://www.skyroadster.com/forums/f5/top-problem-36802/
MidniteBlues is offline
post #11 of 29 (permalink) Old 05-23-2011, 01:59 PM
Quoted: 181 Post(s)
post #12 of 29 (permalink) Old 05-23-2011, 02:33 PM
smartin's Avatar
I have the opposite problem. My top won't open.
I have to replace a hinge.
2008 AGGRESSIVE SOLSTICE GXP
SMARTIN's SOLSTICE
QUEEN
"THE RED ROCKET"
Custom Tune
2006 Deep Solstice
"O Sol O Mio"
11/15/05 - 02/25/12
RE-TIRED
smartin is offline
post #13 of 29 (permalink) Old 05-23-2011, 05:35 PM
G8TR's Avatar
Quoted: 2 Post(s)
Originally Posted by smartin View Post
My top won't open.
Maybe someone could help you with that.
Riding High In My Sky
G8TR is offline
post #14 of 29 (permalink) Old 05-23-2011, 05:42 PM Thread Starter
Looks like my problem is different from those other posts. Its kind of disheartening to find out there are so many other parts that tend to break too. I don't see my part in the diagram. I'll compare it to the car tonight to see if maybe its a part that can be replaced.
If not I will probably try a zip tie or something to hold mine in place before I resort to glue.
post #15 of 29 (permalink) Old 05-23-2011, 06:27 PM
Glue will not work,
Go to the dealer and order the part I give you.
I have them in my glove box and the parts for the back lid also.
They are eazy to brake. And eazy to replace.
Your pick with the parts is not the page you need and on the right one it is part # 14.
lllfly is offline
