UPDATED 12/31/19 GM Issues a Recall of the Passenger Presence Sensor! - Page 43 - Saturn Sky Forums: Saturn Sky Forum
 130Likes
post #631 of 1055 (permalink) Old 03-02-2018, 08:52 AM
I don't think that's right John.
Per the letter:
"Occupant pressure on the seat in the same location can, over time, bend and damage the sensor's printed conductor. In severe cases, this damage can cause an open circuit in the sensor."
That tells me that even if the mat is working, if it is starting to tear it is considered "damaged". I have not seen in the current letter what the repair will be, but in the unofficial repair that was listed before, if the mat wasn't damaged, they would just add the tape but if the mat WAS "damaged" it would be replaced with a new mat that would also be taped.
It comes down to that word...damage. Does the damage have to be into the printed circuit? If the mat is ripped at all is it considered damaged? That's what I don't know at the moment. When I took mine in before, they were looking for a sensor with an open circuit and a failed mat. The above statement in the letter tells me that the mat doesn't have to have the open circuit (which is what trips the error lights and messages) in order to be considered damaged. Thus a working mat could still be considered damaged and thus eligible for replacement.
Good point. The one I took out of the 08 when I bought it was not working but had no damage that was visible without careful examination of the trace so I tend to think they all fail that way.
I haven't seen that anyone has examined a damaged but functional sensor, so there is no indication about how quickly the tear happens and whether it is caused by fatigue (repeated flexing) or acute damage (kneeling in the seat).
You are exactly correct however that a functional but damaged sensor would be replaced, or at least should be.
JohnWR is online now
post #632 of 1055 (permalink) Old 03-02-2018, 10:34 AM
Quoted: 1020 Post(s)
Update: To be exact, do not go over to your GM dealership. This will save you a trip. Call them. They definitely do not have the part. It must be ordered and then you will receive a call when the part arrives.
To answer Robo and Johns concern....I assume it will be one fix for all because my GM dealership didn't ask to inspect my PPS before ordering the part...
I just amended this post...I wrote did...it should have read didn't
marlboromike is online now
post #633 of 1055 (permalink) Old 03-02-2018, 11:57 AM
44thSKY's Avatar
Quoted: 392 Post(s)
Update:
To answer Robo and Johns concern....I assume it will be one fix for all because my GM dealership did ask to inspect my PPS before ordering the part...
MM, could you elaborate on the answer above. I'm reading it that you may have left out a word. Are you saying ..... no questions asked by the dealer ....... everyone gets a replacement, NO MATTER WHAT CONDITION IS OF CURRENT PPS?
44thSKY is offline
post #634 of 1055 (permalink) Old 03-02-2018, 12:03 PM
DaveOC's Avatar
Quoted: 9 Post(s)
For what it is worth, there are two part numbers. Which you get is determined by whether the existing seat sensor is "damaged". The dealer must examine the seat to determine which part to use, the sticky tape part, or the sticky tape already installed on a new seat mat.
BTW, some dealers don't read real well either!
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #635 of 1055 (permalink) Old 03-02-2018, 12:16 PM
TerryJ's Avatar
Quoted: 36 Post(s)
Seat sensor recall letter
Received my Recall letter from GM today. TLJ
"Man cannot live by Bread alone, He must have Peanut Butter"
TerryJ is offline
post #636 of 1055 (permalink) Old 03-02-2018, 12:47 PM
44thSKY's Avatar
Quoted: 392 Post(s)
DaveOC, so the words "The dealer must examine the seat" means the bottom seat cover must be removed in order to see which condition exists? Correct?
So this would tell me the steps above would tell the dealer which part to order. Now they put the seat back together as when you arrived, send you home, and you wait for the dealer to call to schedule a return for the actual work to be performed. My questions, just so I understand what to expect of the sequence of events.
44thSKY is offline
post #637 of 1055 (permalink) Old 03-02-2018, 12:57 PM
Bill...I just amended my post. Hope that helps.
post #638 of 1055 (permalink) Old 03-02-2018, 02:47 PM
DaveOC's Avatar
Quoted: 9 Post(s)
So . . . before I can answer this, I'll need to talk to my dealer service manager, there is a grey area where the seat mat can be "damaged" but be intact enough to still pass the "put an adult in the seat and see if it registers the airbag is on" test, at least according to Robotech.
So . . . I don't have an answer to your question, but I'll stop this afternoon while I'm out and ask.
Dave -
DaveOC is offline
post #639 of 1055 (permalink) Old 03-02-2018, 03:13 PM
Rusty Boltz's Avatar
Quoted: 160 Post(s)
I heard back from my service advisor late yesterday. He said he "ordered the parts" and will call me to set up an appointment when they come in.
07 Sky
2.4L NA
5 speed
Limited slip differential
Chrome wheels
Premium trim package
Monsoon audio
AM/FM/XM/CD changer
Rusty Boltz is offline
post #640 of 1055 (permalink) Old 03-02-2018, 05:20 PM
DaveOC's Avatar
Quoted: 9 Post(s)
I now have the dealer procedure document available to me, so here goes my paraphrase of the document.
Step 1: With the vehicle ignition key in the "on" position, have an adult weighing at least 150 lbs. occupy the passenger seat. Observe the passenger airbag telltale. It should change from "off" to "on". If the passenger airbag telltale indicates that the airbag is on, proceed to the part of the instructions that deal with installation of the adhesive backed reinforcement strip. If the passenger airbag telltale indicates that the airbag is NOT on, proceed to the part of the instructions that deal with the replacement of the inflatable restraint passenger presence module in addition to performing the installation of the reinforcement strip.
At this point, they should know which parts to order, and the seat cover has not been removed. In order to do either repair, the seat cover needs to be removed.
Part numbers:
4 Retainer - Seat Cover #10121502
1 Reinforcement - Passenger Presence Sensor #84447742
1 (if required) Module - Passenger Presence #19124219
My comment: The diagnostic part of this does not require visual examination of the sensor mat, and is done with the seat cover on. The only question is whether the dealer needs to order the the sensor mat as well as the reinforcement strip. The mats are not coming with the reinforcement strip pre-assembled.
The document is 8 pages long and mostly deals with the replacement of the passenger presence module.
Did this answer your questions:
@marlboromike @44thSKY @JohnWR @Robotech
Dave -
DaveOC is offline
post #641 of 1055 (permalink) Old 03-02-2018, 06:00 PM
Quoted: 525 Post(s)
So that says the mat has either failed or not, and "damaged" = failed. So anyone with a mat that has started to crack (but not yet failed) just gets the tape and no replacement.
Thus, for me (when I DO get to do this), I will check the mat myself and if there IS any damage/cracks, will exacerbate it to the point it fails. I'll have to remove the cover anyway to remove my seat heater mat (to avoid 'difficult questions').
Please note: for those of you who've not seen a naked mat, there is a heat-glued felt material cover over top of the sensor mat. So it's not easy to see if you have damage or not, even with the seat cover off. THAT raises the question @DaveOC, what does the dealer procedure document say about replacing that felt cover?
44thSKY likes this.
TomatoSoup is offline
post #642 of 1055 (permalink) Old 03-02-2018, 06:23 PM
44thSKY's Avatar
Quoted: 392 Post(s)
As TS describes, his intention is to further the damage thus the complete pad will be replaced.
SO, this leads to the question, for those whose pad has not yet failed (but a failed diagnosis), is the recall step when completed per the diagnosis described mean the recall obligation for any future failure the responsibility of the owner?
If SO, what is the end date for an owner to take his car in on the recall? (my PPS units seem to be working correctly now)
44thSKY is offline
post #643 of 1055 (permalink) Old 03-02-2018, 06:35 PM
DaveOC's Avatar
Quoted: 9 Post(s)
"Refer to Inflatable Restraint Passenger Presence System Replacement - System in SI.
That was a lot of help, correct?
Are these pics of the felt cover, I've never removed the seat cover myself? If I'm reading this correctly, the reinforcement strip is adhered to the felt.
OK get out the scanner, here's how to install the reinforcement strip, I don't recognize the pad.
NOTE: Attachments removed 3-3-18
Dave -
DaveOC is offline
post #644 of 1055 (permalink) Old 03-02-2018, 06:39 PM Thread Starter
Quoted: 1816 Post(s)
Yes, but then it contradicts what their remedy says in the letter. At this point, what they're testing above is an open circuit failure and that is the only way they are replacing a "damaged" mat. If the mat is torn but still functional, it is compromised. However that can only be determined if you open the mat.
post #645 of 1055 (permalink) Old 03-02-2018, 06:59 PM
All these Q&As...that is why I write...taking the car into the GM dealership is Dum De Dum...and no matter what instructions are given, u will have to rely on the literacy of the service tech....EGAD!
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
