VSS (Sensor) Location - Saturn Sky Forums: Saturn Sky Forum
post #1 of 5 (permalink) Old 10-27-2019, 02:26 PM Thread Starter
Hello I have a 2007 Sky Automatic and need to replace the VSS, I cant find any info as to where its located in the vehicle, any Ideas? Thanks in advance
juncos is offline
post #2 of 5 (permalink) Old 10-27-2019, 03:19 PM
Junior Member
Pattsullivan's Avatar
Quoted: 33 Post(s)
I would assume its somewhere in the trans. Never had to replace mine though.
Pat
Pattsullivan is offline
post #3 of 5 (permalink) Old 10-27-2019, 04:16 PM
Junior Member
Quoted: 528 Post(s)
Part #42 or 44 here (on the transmission):
[From: https://www.wholesalegmpartsonline.c.../96041860.html ]
TomatoSoup is offline
post #4 of 5 (permalink) Old 10-27-2019, 06:46 PM Thread Starter
Thanks, I guess the trans need to be drained? Getting More interesting
juncos is offline
post #5 of 5 (permalink) Old 10-27-2019, 09:00 PM
The replacement procedure starts out with: "Remove the transmission fluid pan and filter'"
As I interpret this and the drawings, the speed sensors are inside the transmission.
So, Yes, draining the fluid is necessary.
How certain are you that it has to be replaced?
JohnWR is online now
