Coolant bleed procedure - Saturn Sky Forums: Saturn Sky Forum
DDM Works
 1Likes
post #1 of 23 (permalink) Old 08-02-2011, 09:20 PM Thread Starter
Mr.Burns@DDMWorks's Avatar
Hello everyone,
We made another video! This time we walk through the coolant bleed procedure that we use here, which is taken from the GM tech manual. While customers have been doing our 2871 turbo upgrade they had some questions about the proper way to bleed the cooling system. This will also help if you had to replace the water pump, thermostat, or installed some other larger turbo. Let us know if you have any other questions or suggestions for other videos.
-Mr. Burns
[email protected]
emlec1992 likes this.
post #2 of 23 (permalink) Old 08-04-2011, 05:05 PM
I have bookmark this post.
If you have not seen this VID you need to.
A great post thank you DDMWorks and all.
2nd American Legends 2013
lllfly is offline
post #3 of 23 (permalink) Old 01-28-2012, 10:10 PM
Gabes Redline's Avatar
Quoted: 13 Post(s)
More Videos Mr. Burns!!! A video on clutch, water pump and turbo change for the DIYers would be freakin awesome!!! Thanks so much for this.
2008 Redline, 5-Speed, Silver/Pearl, Red Leather
DDMWorks Brace Bundle/Kappa Shifter/Charge Pipes
Pedders XA Coilovers
Solo Performance Hi-Flow Cat
RPI GT Exhaust/RPI CAI MOD
Hahn Racecraft Intercooler
Gabes Redline is offline
post #4 of 23 (permalink) Old 01-28-2012, 10:54 PM
GASNGO's Avatar
Thumbs up
Nice job. Very helpful.
Thank You, Jerry
GASNGO is offline
post #5 of 23 (permalink) Old 01-29-2012, 11:31 AM
RickyD's Avatar
Quoted: 70 Post(s)
Hey Dave I have a thought
First, love the video but I think there are a couple things you might want to mention or make a separate video.
First It looks like you put 1 gallon of coolant in. The cars take a little over 8 quarts or 2 gallons. The Engine and tank take that but the complete system as you know takes twice that.
Because 4 cylinders are so very prone to air locks in the coolant system that I have seen take up to a hour to get it all out. You might want to make another video for when you completely drain the system as if you were changing the radiator. I know gravity take care of most of it but if someone for some reason drains the radiator but only puts in 1 gallon its not going to be enough. Just a thought.
When the dealer changed mine they have a vacuum system that sucks all the air and coolant out and gives the system a negative pressure so when it goes back in it fills everything. Its really cool.
Soon to be a LS3 but:
Lysholm 1.6 supercharger
T56 6 speed transmission
2.4 with L61 cyl head
Non VVT comp cams
DDM long tune header.
RK hood & Grnd Effects
DDMWorks suspension mods
AEM Meth Injection kit.
Elect exhaust cutout
VDI Doors
RickyD is offline
post #6 of 23 (permalink) Old 01-30-2012, 12:18 AM
DURAMAX's Avatar
Is this as complicated on the NAs?
2008 2.4 AUTO MIDNGT BLUE BLK TOP BLK LTHR gone but not forgotten.
2008 Vette Jetstream Blue
2003 Silverado Arrival Blue
1998 Vette Black
DURAMAX is offline
post #7 of 23 (permalink) Old 01-30-2012, 06:55 AM
miller11386's Avatar
Quoted: 18 Post(s)
He states in the video it is the same procedure for NA's, you just dont have the coolant return line for the turbo.
miller11386 is offline
post #8 of 23 (permalink) Old 06-12-2012, 07:32 PM
|V3nom|'s Avatar
how about a coolant draining video? also where do you bring coolant to be disposed of?
GM Stage 1 Tune|Solo Street Race Exhaust With Magnaflow Mufflers|GMR 8K HIDs|Parking Light Leds|License Plate Leds|Little Chromies|3rd Brake Light Vinyl:REDLINE|GMR Pulsating and Sequential Taillights|
|V3nom| is offline
post #9 of 23 (permalink) Old 10-01-2012, 07:59 PM
09SkyGuy's Avatar
Coolant level too high (?)
So I added some Redline WaterWetter to my reservoir today... course I forgot to REMOVE some coolant prior to. Now the level is about .75" above the level line. Should I be concerned? I could just syphon off the extra I guess, but I'm not sure the WaterWetter has mixed into the system yet. Does the coolant cycle through the reservoir when running? Or is that just an overflow that basically sits stagnant until it's needed? Took a 15 mile drive to test temp... no real change good OR bad.
Is that stuff just another snake oil thing?
Thanks!
09SkyGuy is offline
post #10 of 23 (permalink) Old 10-01-2012, 08:05 PM
Sky_Pilot's Avatar
Quoted: 100 Post(s)
Do you guys happen to have one for bleeding the brake lines?
Sky_Pilot is offline
post #11 of 23 (permalink) Old 10-01-2012, 09:22 PM
Junior Member
Quoted: 529 Post(s)
Thanks!
Water wetter is good when added to plain water. When added to Dexcool, not so much. Maybe a couple of degrees improvement max.
Won't hurt, except for money wasted.
TomatoSoup is online now
post #12 of 23 (permalink) Old 10-01-2012, 11:02 PM
carnut122's Avatar
Quoted: 4 Post(s)
I changed out my coolant yesterday. I was unable to get gravity to pull the coolant through until it came out of the top of the head, so I had to put some pressure behind the coolant in the overflow to make that happen. It rained today, so I'll drive it soon to make sure it's up to capacity.
carnut122 is offline
post #13 of 23 (permalink) Old 10-02-2012, 03:05 AM
|V3nom|'s Avatar
i can not stress enough how much this company helps with bleeding the brakes. i have their bleeder and will never use another product unless its better lol which i doubt will happen. might be a little pricey at first but itll last a lifetime. easiest way to bleed the brakes by far and its only a one person job.
http://www.motiveproducts.com/
|V3nom| is offline
post #14 of 23 (permalink) Old 10-02-2012, 10:22 AM
Sky_Pilot's Avatar
Quoted: 100 Post(s)
Motive Products #1 Selling DIY Brake Bleeder
I like! So does ours use kit 0108/0118 with the 1108/1118 adapter or kit 0100/0109 with the 1100/1109 adapter? Also, I "thought" that one of the peculiarities of our Kappa's was that the same fluid that stops the car also enables our clutch. If that's the case, does this method cause any issues with or are there other steps to take in bleeding refilling the entire system?
post #15 of 23 (permalink) Old 10-02-2012, 05:28 PM
|V3nom|'s Avatar
i think i have the 1100 adapter, the european one, because the normal gm one doesnt fit. i had to send mine back for the 1100 because of this.
i havent had any issues since i bled the brakes and i have a manual tranny so id say it doesnt cause any problems. all youre doing is pushing new, good fluid through the system so i dont see how it would cause a problem. this system is set up to NOT push any air into the lines. if done correctly the longest part of bleeding the brakes is getting the car up, that is if you dont have a vehicle lift.
|V3nom| is offline
  Saturn Sky Forums: Saturn Sky Forum > Vendors > DDM Works
