Sound system upgrade? - Saturn Sky Forums: Saturn Sky Forum
SKYRoadster News News related to the Saturn SKY as well as site news. Only Administrators may create new threads in this section.
 13Likes
post #1 of 49 (permalink) Old 04-27-2018, 07:54 PM Thread Starter
snkhill55's Avatar
Quoted: 6 Post(s)
Looking for a sound system and all I saw was old news. Wondering if there was a newer solution, thanks.
snkhill55 is offline
post #2 of 49 (permalink) Old 04-28-2018, 01:09 AM
Emmett's Avatar
Quoted: 84 Post(s)
My local sound guy is a great auto mechanic.
For interior work his hourly rate is reasonable too.
He's installed a new shifter, skyfall, santana cup-holder (for free), door handle, weather stripping.
I like his work so I asked him to swap out the door speakers with the best speakers he has.
He decided on full sound top of the line Kenwoods.
The installation and the speakers set me back... I recall $240.
But I'm so glad I upgraded. The sound is WAY WAY better.
I'm going to have him swap out the passenger/wolfer next week.
I still have the Saturn radio.
Yeah, it used to be my SL2 - which has a custom sound system had nicer sound... but not now.
Emmett is offline
post #3 of 49 (permalink) Old 04-29-2018, 09:44 PM
Quoted: 1672 Post(s)
The head unit alone will make a big change. With the stock unit I could barely hear the radio with it cranked and top down on the highway. With a new Kenwood unit, I never go above about 50% and this is on the stock speakers. I'd do the head unit first and see where that puts you before doing the rear speakers and sub.
mstrjon32 and Rockchops like this.
post #4 of 49 (permalink) Old 04-29-2018, 10:27 PM
Quoted: 39 Post(s)
This. Giving a good signal to everything downstream is much much more important, and usually the biggest bottleneck. I've scoped out total systems on most cars I've had and in many cases a decent HU just wakes everything up and you can understand the gaps in the system. The sky was definitely one of those that just needed a good HU...the monsoon amp seems to have a pretty clean sub cutoff around 100hz and is super easy to EQ since there aren't too many variables in it.
mstrjon32 likes this.
Rockchops is offline
post #5 of 49 (permalink) Old 04-29-2018, 10:36 PM
I keep kicking around the idea of going with a new head unit just to incorporate Android Auto. My current unit can control my phone but only through a special HDMI cable and the adapter I have to use for the phone for that cable is VERY fragile. I've gone through three and the current one it broke too...so I just do Pandora through bluetooth. I'd rather have the full function back as I once did. I can't even use the Pandora ap on the head unit without it being plugged in to this cord.
post #6 of 49 (permalink) Old 07-26-2018, 11:34 AM
rojam35's Avatar
Quoted: 21 Post(s)
Stopped into local car audio shop. Talked about a system upgrade. The initial quote for a basic HU replacement was $757. I appreciate the need to get the proper fit and console pieces but this seems a bit high for just the HU. I guess I'll stay with the stock unit and turn it up.
rojam35 is offline
post #7 of 49 (permalink) Old 07-26-2018, 12:48 PM
wspohn's Avatar
Quoted: 329 Post(s)
I'll differ on the order of modification.
I change speaker drivers first. OEM drivers are notoriously the cheapest - shall we agree on 'crap'? You can often effect a noticeable improvement by simply fitting better more expensive drivers - in the Kappas I suggest the door speakers and the tweeters (the rears have less effect on the musical experience, and the subs are hard to find an improvement for using anything like the stock enclosure).
Beyond that the head unit will certainly have limitations, but the advantage of it is that it is an anti-theft device all on its' own - no one will want to steal a factory stereo while they will usually jump at a marketable after market unit.
Frankly, unless you already have a good home stereo, I'd say to put that head unit upgrade money into the home system where you can really enjoy it.
syjos likes this.
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
1971 Jensen Interceptor
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
wspohn is offline
post #8 of 49 (permalink) Old 07-26-2018, 03:15 PM
Quoted: 476 Post(s)
Beyond that the head unit will certainly have limitations, but the advantage of it is that it is an anti-theft device all on its' own - no one will want to steal a factory stereo while they will usually jump and marketable after market unit.
I completely agree with everything written above ^^
TomatoSoup is offline
post #9 of 49 (permalink) Old 07-27-2018, 10:57 PM
I just changed my head unit and it was a major difference for me. Before top down I had to crank the stock unit all the way up and I still could just barely hear it. Now, never have to go past half way and I hear it a lot better than the stock unit.
post #10 of 49 (permalink) Old 07-28-2018, 05:25 PM
christopher_2's Avatar
Quoted: 71 Post(s)
Monsoon setup ?
2007 (2.4L)
Solo Cat
Magnaflo Redline dual exhaust
Werks Turbo @ 10 PSI
FE2 shocks
ZOK anti-sway bars
christopher_2 is offline
post #11 of 49 (permalink) Old 07-29-2018, 09:40 AM
Quoted: 137 Post(s)
Can't agree enough with Robo, the first thing to change is the stock head unit, it's an absolute pile of crap. I changed mine to a Pioneer 80PRS anticipating that I'd start replacing the drivers soon after, and guess what--the speakers are just fine, the stock HU just doesn't have the power to drive the system. Could probably benefit some by replacing them, but replacing that garbage stock head unit woke up the entire system and with just a little bit of tuning it sounds clear and powerful and I often sit in the car to just listen to music after I've arrived at my destination.
mstrjon32 is online now
post #12 of 49 (permalink) Old 07-29-2018, 02:40 PM
Originally Posted by christopher_2 View Post
Monsoon setup ?
Yes, mine has a Monsoon system.
post #13 of 49 (permalink) Old 07-31-2018, 11:18 AM
Quoted: 920 Post(s)
If u want to crank up the sound...why didn't anyone install the USB head unit from any of the chevys? It will rip your speakers apart if u turn it up...that extra amp is all u need when driving with your top down...and u can always upgrade your speakers.
Please don't tell me about sound quality...our cars are not sound proof and when the top is down...u have too much distraction from noises.
marlboromike is online now
post #14 of 49 (permalink) Old 07-31-2018, 02:25 PM
Blue Tooth, Pandora, Navigation, touch screen, DVD...few other features other than better volume came with it too...
post #15 of 49 (permalink) Old 07-31-2018, 03:28 PM
Quoted: 137 Post(s)
You don't need to be in a cone of silence to enjoy a nicely tuned system, and unless you add a separate DSP to clean up the absolute mess of a signal coming out of the stock deck then a quality aftermarket unit is the only alternative.
I'm a big fan of having the single DIN unit in there as well as it provides easy to reach and useful extra storage space.
  Saturn Sky Forums: Saturn Sky Forum > SKYRoadster News & Polls > SKYRoadster News
HTML code is On
