Backbone install lifting 1 side of car - Saturn Sky Forums: Saturn Sky Forum
Sponsored by Discount Tire
 3Likes
post #1 of 39 (permalink) Old 12-27-2018, 11:48 PM Thread Starter
davhamm's Avatar
Quoted: 445 Post(s)
Sometime in the future I will get the backbone on my car. Cause its in the garage, it would be easier to jack up one side instead of the rear. Could you install a backbone that way, or no I should put it on the drive and lift the rear end to do the job?
I am a GM Engineer.
2009 HYDRO REDLINE AUTO
davhamm is offline
post #2 of 39 (permalink) Old 12-28-2018, 01:32 AM
greatgab's Avatar
Quoted: 5 Post(s)
I used four jack stands when installing mine... figured a level car (no twist) would give me a truer and easier install. I would avoid using our square pumpkin diff as a jacking point - plus you'll need the space to drop the exhaust for the install.
greatgab is offline
post #3 of 39 (permalink) Old 12-28-2018, 02:48 AM
skersfan's Avatar
Quoted: 751 Post(s)
Davham,
I think the rear approach is to take the compression out of the shocks/spings and give more clearance for the drive shaft, if I remember correctly. I did mine a long time ago and the other two were done on the lift at the shop.
skersfan is offline
post #4 of 39 (permalink) Old 12-28-2018, 05:40 AM
Quoted: 859 Post(s)
Why struggle with this simple replace. When u get an oil change...give the guy an extra 10 or 20 dollars. This is not rocket science. 8 or 10 screws. The car is on the lift. It is FINISHED. The backbone slides in and out. It is not worth the struggle. Even doing this simple task...u need to choose your battles.
marlboromike is offline
post #5 of 39 (permalink) Old 12-28-2018, 07:33 AM
Quoted: 19 Post(s)
I had mine installed by a local auto shop for $30 including dropping the exhaust and checking the car out while on the lift. Just make sure they know the correct way to lift the car.
2009 Saturn Sky Red Line SE Ruby Red 5M
Trifecta tune
Windrestrictor
DDM short shifter
DDM brace bundle
Solo Performance Quad Tips
Lil' Chromies
Full LED lights
LED footwell lights
Trunk Gas Strut Mod
Kappa Rack
JPM Leather Console
Sky By Nite is offline
post #6 of 39 (permalink) Old 12-28-2018, 02:50 PM Thread Starter
davhamm's Avatar
Quoted: 445 Post(s)
Exhaust is in the way, not driveline.
Had not seen video but does answer an earlier question, had anyone backed up onto ramps with rear tires. (Looks like he did with all 4)
They guy who changes my oil is asking the question
Paranoid about having anyone else working on the car.
I am a GM Engineer.
davhamm is offline
post #7 of 39 (permalink) Old 12-28-2018, 03:20 PM
Quoted: 1607 Post(s)
I would NOT install the back bone...or any bracing...without the car being level. Whether it is on a lift or jack stands, make the car level.
While there isn't a LOT of play in the screw holes, there is some and it's enough to tweak the car a bit. I am anal about this kind of stuff (ask me about setting tweak on my RC cars....) so I wouldn't do it any other way.
Robotech is online now
post #8 of 39 (permalink) Old 12-28-2018, 03:27 PM Thread Starter
davhamm's Avatar
Quoted: 445 Post(s)
Ok, now you just pointed the spot light on that nagging thought in the back of my head... I figure I was just being anal, if no one ever said anything... well not anymore..
I am a GM Engineer.
davhamm is offline
post #9 of 39 (permalink) Old 12-28-2018, 06:19 PM
Davhamm, I'm right there with your sir. Chances are we would never notice...
...but we'd know. Oh yes, WE'D KNOW!!!!! LOL
post #10 of 39 (permalink) Old 12-28-2018, 06:24 PM
Quoted: 859 Post(s)
I viewed my install and...how can the muffler be in the way. The muffler is in the rear end. It is just a muffler pipe...and all they do is slide the old backbone out and slide the new one in...all of you are making a simple unscrewing MASSIVE.
post #11 of 39 (permalink) Old 12-28-2018, 06:39 PM Thread Starter
davhamm's Avatar
Quoted: 445 Post(s)
Ok I misspoke the muffler is not in the way, the exhaust pipe can be, so most drop the muffler's which then lowers the muffler pipe out of the way. Can it be done without, sounds like from your experience yes, but most drop them because it is pretty easy to do and improves access.
I am a GM Engineer.
davhamm is offline
post #12 of 39 (permalink) Old 12-28-2018, 06:42 PM
Quoted: 859 Post(s)
Nothing has to be dropped. Period. The hardest part on this job is loosening the screws. They are difficult to remove if u do it without a lift.
Many olde timers did it themselves...just by crawling under the car...not recommended if you are fat.
post #13 of 39 (permalink) Old 12-28-2018, 06:42 PM
greatgab's Avatar
Quoted: 5 Post(s)
I put in DDM's thickest brace... no way it was going in without dropping the exhaust.
2008 GXP Aggressive Red - SOL LVR - Trifecta custom tune - DDM CAI/charge tubes/silicone hoses - Werks IC - Solo Hi-flow Cat/Mach Shorty exhaust - DDM Probeam/Backbone/Venom brace - Short throw shifter - Full LED conversion - Michelin Pilot Sport 4S
greatgab is offline
post #14 of 39 (permalink) Old 12-28-2018, 06:47 PM Thread Starter
davhamm's Avatar
Quoted: 445 Post(s)
Reading more closely I did not say muffler I said Exhaust..
I am a GM Engineer.
davhamm is offline
post #15 of 39 (permalink) Old 12-28-2018, 06:48 PM
Quoted: 859 Post(s)
This may need to be qualified....I have an NA...only one engine pipe. R/L I believe is different. And I had the original DDM Backbone installed.
