Original OEM Tires - Saturn Sky Forums: Saturn Sky Forum
Sponsored by Discount Tire
 4Likes
post #1 of 25 (permalink) Old 01-02-2017, 01:41 PM Thread Starter
jaleonard3's Avatar
Original OEM Tires
Hi folks,
My 2009 Sky Redline has accumulated only 5200 miles since new. As you can imagine, I am still running the OEM tires. Recently, I've noticed these tires have become very slippery (lacking grip) and the car is considerably more "loose" to drive. I've checked the inflation on all four tires and am right at the recommended pressure. Do these tires harden over time on their own? I live in South Texas so when I do drive the car, the asphalt can be quite hot. I'm thinking the rubber compound has hardened due to a combination of heat and age. Anyone have any experience with this? I can certainly replace the tires but it seems odd to do so when I have lots of remaining tread life.
Thanks!
Jeff Leonard
2009 Hydro Blue Red Line LE, Manual, Bone Stock
jaleonard3 is offline
post #2 of 25 (permalink) Old 01-02-2017, 01:46 PM
Quoted: 429 Post(s)
You are exactly right. Replace them right away. The rubber ages, grip worsens, ride worsens and the tendency for blowouts and/or tread separation increases.
It's not (just) a mileage thing, it's an age thing.
jaleonard3 likes this.
TomatoSoup is offline
post #3 of 25 (permalink) Old 01-02-2017, 02:11 PM
Quoted: 1607 Post(s)
Yes, at 8 years of age your tires are probably done. Your experience with them lacking grip confirms this. It is time to replace them and depending on what you want out of them, there are a lot of choices. Living in South Texas if you're not seeing a lot of rain...and absolutely no snow...you can go with a more aggressive Summer tire. I'm assuming since you have only 5000 miles on it that you only drive it in summer, in good weather, and just for pleasure. As such all season radials would not be a good choice.
Robotech is online now
post #4 of 25 (permalink) Old 01-02-2017, 02:55 PM
ChopTop's Avatar
Quoted: 138 Post(s)
ChopTop is offline
post #5 of 25 (permalink) Old 01-05-2017, 07:44 PM Thread Starter
jaleonard3's Avatar
Thanks everyone for the comments and advice. Time for new tires!
Jeff Leonard
post #6 of 25 (permalink) Old 01-17-2018, 09:29 PM
backroad101's Avatar
Quoted: 22 Post(s)
What were the OEM tires on a 2008 Redline? Trying to determine if my tires are still the originals. Goodyear Eagle F1s?
2008 Silver Redline - Fully loaded
backroad101 is offline
post #7 of 25 (permalink) Old 01-17-2018, 09:50 PM
Quoted: 39 Post(s)
Yup. You got it
Flashy is offline
post #8 of 25 (permalink) Old 01-21-2018, 10:45 AM
Quoted: 54 Post(s)
Check the date code on the side of the tire. If the original owner bought the same crappy tires to replace his original tires you'll not be able to tell if the tires are original by looking at the make of the tire. Those tires are so bad I'm surprised that the original owner lived long enough to be able to sell the car.
tallcraig likes this.
Sly Bob is offline
post #9 of 25 (permalink) Old 01-21-2018, 11:27 AM
DaveOC's Avatar
Quoted: 9 Post(s)
That is good advice. But one of the things I have always been good at is adjusting my driving style to fit within the parameters of the patch of rubber that is in contact with the road, regardless of the design of that patch.
The main problem with the original tires (Goodyear RS-A) is that they were designed for a heavier car than the Solstice and Sky.
YMMV
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #10 of 25 (permalink) Old 01-21-2018, 11:58 AM
Quoted: 54 Post(s)
If I remember correctly the RS-As were on the non-turbo cars.
Sly Bob is offline
post #11 of 25 (permalink) Old 01-21-2018, 12:21 PM
DaveOC's Avatar
Quoted: 9 Post(s)
Goodyear F1 - GS-2. They never did like to be cold, as they get older they really, really don't like the cold mid-western weather.
Dave -
DaveOC is offline
post #12 of 25 (permalink) Old 01-21-2018, 12:47 PM
Quoted: 54 Post(s)
This is how to read a date code on your tires for those that are unfamiliar with the means to do so.
https://www.tirebuyer.com/education/...-of-your-tires
Sly Bob is offline
post #13 of 25 (permalink) Old 01-21-2018, 08:09 PM
Quoted: 39 Post(s)
Good! I finally have a way to get a date!
Flashy is offline
post #14 of 25 (permalink) Old 01-21-2018, 08:12 PM
Quoted: 39 Post(s)
Seems like while I used to wear out tires or swap them due to damage, I replace them more now from age. Either I am driving like a grown up, double-wishbones are easier on tires, or the tires are better.
Maybe all of the above.
Flashy is offline
post #15 of 25 (permalink) Old 01-21-2018, 08:56 PM
Quoted: 22 Post(s)
I could have sworn I had the Goodyears. Maybe that was the Redline I test drove before I got this one.
Anyway I have Michelin Pilot Sport A/S3, fronts from 2012 and rears 2014. I'm glad as I did not want to have to buy tires for the stock rims if I end up getting different rims. Now I have time.
I looked them up on Tirerack and they are rated so so, but really only in weather conditions the car is not driven in. The A/S3 Plus are rated a lot better. Anyway, they will work for now
Would You Recommend? 6.4 - Fair
Wet Performance 8.7 - Excellent
Dry Performance 9.0 - Excellent
Winter/Snow Performance 4.8 - Fair
Comfort Performance 8.0 - Good
Treadwear Performance 6.5 - Fair
