Sky High-Flow Catalytic Converter - Saturn Sky Forums: Saturn Sky Forum
Solo Performance
post #1 of 19 (permalink) Old 03-03-2009, 08:24 PM Thread Starter
GOINGSOLO2's Avatar
SOLO Performance is proud to offer our Sky High-Flow Catalytic Converter. Our cats are a full stainless steel converter. The external are a polished T409 stainless with laser-cut stainless flanges. The internal are a stainless wound 200 cell coil converter. We are able to keep the engine light off with our converter. We decided to go with a 5" internal wound coil. We chose the substantially more expensive 5" internal wound coil because:
  • More substance inside enables exhaust gasses to be more thoroughly cleaned.
  • The 5" coil lasts longer than the traditional 3" coil because there is more surface area cleaning the exhaust gasses.
  • The sound quality is better. It is softer and less harsh.
  • Each individual coil is tack welded to prolong life.
  • Any SOLO High-Flow Catalytic Converter will increase volume by approximately 15%.
Sound Clips and Videos
Sky High-Flow Catalytic Converter- $290
Shipping- $30
Send me a PM with any questions, concerns, and/or order inquiries.
Name:	NA SKY CAT.jpg
ID:	31248   Click image for larger version
Name:	NA SKY CAT2.jpg
GOINGSOLO2 is offline
post #2 of 19 (permalink) Old 03-03-2009, 08:26 PM
Bump for a great company. These guys do great work!!
2008 Infiniti G37S Coupe 6MT - 58k - Megan Axle Back
2007 Sky Red Line 5-Speed - 79k - Light mods
2006 Saturn Vue 5-Speed - 103.4k
Koobie is offline
post #3 of 19 (permalink) Old 06-08-2010, 05:07 PM Thread Starter
GOINGSOLO2's Avatar
Spring and summer are here! Hook up your Sky with one of our great exhaust kits be the one that turns heads! You can reach me anytime with questions or to order at 516-655-9002. You are now also able to order through our website at : Welcome to Solo Performance : For Mufflers, Exhaust, Stainless Steel Tubing and Mandrel Pieces. Pics, Video, Installation.....Order Online.
Steve
post #4 of 19 (permalink) Old 07-26-2010, 10:37 AM
I just got a bulliten a few days ago from SCCA Solo board stating that they require replacement cats to be EPA aproved and that they would be checking for the appropreate stickers. Are these EPA aproved?
From the buliten:
Street Touring: Information regarding catalytic converter types and EPA labeling, as referenced in 14.10.E, can be found
on the EPA’s web site in this document: “What you need to know about using, installing, or buying aftermarket catalytic
converters” at http://www.epa.gov/otaq/cert/factshts/catcvrts.pdf. In addition, California has recently moved to CARB
certification for aftermarket cats, so a CARB “EO” number also meets the EPA labeling requirements (ref. #1439)
Eagle_f90 is offline
post #5 of 19 (permalink) Old 07-27-2010, 03:08 PM Thread Starter
GOINGSOLO2's Avatar
The converter in its generic form is EPA approved. Once it is manufactured into a direct fit converter for the Sky/Solstice, it is not EPA approved.
post #6 of 19 (permalink) Old 07-27-2010, 03:19 PM
And the way you sell it is considered direct fit right?
post #7 of 19 (permalink) Old 07-27-2010, 03:41 PM Thread Starter
GOINGSOLO2's Avatar
Correct...they were made to fit the Sky without any modification. It depends how specific the SCCA is about being EPA approved. If they just mean the converter body itself, then you should be fine. If they mean the converter after it is made to fit the car, then you might have an issue.
post #8 of 19 (permalink) Old 07-28-2010, 09:24 AM
I am 99% sure they just mean the converter it's self. Thanks for the help, defently adding this to the list of parts to buy now to find money.
post #9 of 19 (permalink) Old 07-28-2010, 10:55 PM Thread Starter
GOINGSOLO2's Avatar
Awesome Let me know if there is anything I can help you with.
post #10 of 19 (permalink) Old 08-16-2010, 12:19 AM
McLovin's Avatar
I've had mine for about 7 months now. I am very happy with it. You definitely notice a power boost when your rpms are running up.
I had my chip programming modified with the GM cat back. After this, I added the Cat and the street race exhaust with two dampeners. The car runs great and not too loud. I could probably get more performance with another modification to the programming however.
2008 Redline Sky
White Exterior/Black/Red Interior
Leather upgrade
GMR Tune, GM CAI Intake, Solo Performance Cat and Street Race Exhaust, Dejon IC Pipes, Sport suspension upgrade, Monsoon Stereo, Opel Short Antenna
McLovin is offline
post #11 of 19 (permalink) Old 12-20-2011, 07:41 PM Thread Starter
GOINGSOLO2's Avatar
post #12 of 19 (permalink) Old 04-18-2012, 11:38 AM
Send a message via MSN to mikecronis Send a message via Yahoo to mikecronis
I've been warned by the owner last year that this is WAY too loud, but if there's gains, I still want it. I wonder if he'd make a deal with me?
mikecronis is offline
post #13 of 19 (permalink) Old 04-19-2012, 11:45 PM
GaryH's Avatar
Is this the same high flow Solo cat that I bought? The one that pluged up just before the engine blew.
07Silver Pearl
Black/Black leather
CD/MP3 XM satellite
5 speed manual
VIN#1745
Fiamm horn
Magnaflow Quad Tip Exhaust
GMPP CAI Kazera KZ-J rims
08 Carbon Flash
DDM Backbone brace
Mach exhaust
GaryH is offline
post #14 of 19 (permalink) Old 04-22-2012, 12:36 PM Thread Starter
GOINGSOLO2's Avatar
Not sure what you mean. We have not had issues with the converters plugging up unless an improper tune was flashed where the A/F ratio is too rich. With this, any aftermarket cat would plug. We have hundreds of these on the road with no issues. Feel free to give Jeff a call at 905-703-1557.
Steve
post #15 of 19 (permalink) Old 05-08-2012, 12:55 PM
Now going for $405 instead of $290? Is this the same one or were there some upgrades to the earlier model; or is it just a supply and cost issue for the materials? So far, SOLO is #1 for exhaust in my book.
  Saturn Sky Forums: Saturn Sky Forum > Vendors > Solo Performance
