Sky Redline MACH Exhaust Kit - Saturn Sky Forums: Saturn Sky Forum
Solo Performance
post #1 of 23 (permalink) Old 03-03-2009, 07:12 PM Thread Starter
GOINGSOLO2's Avatar
SOLO Performance is proud to offer the Sky Redline MACH Exhaust Kit. The MACH system is SOLO's quietest exhaust for the Sky Redline. This Sky Redline MACH kit was developed primarily for people that want quieter high performance. This system uses SOLO’s MACH series dual in, dual out, true X design muffler. Here are some attributes of our Sky Redline MACH system:
  • Dual Exhaust with the free flow MACH muffler.
  • Front Section- Full 3" mandrel stainless pipe with laser cut stainless flange, stainless oxygen sensor bung, 3" double braided flex pipe and additional hanger bracket. This 3" section actually sits ¼" to ½" higher than the stock 2 ½” exhaust.
  • Rear Section – A 3” in, 2 ½” dual out, stamped stainless Y pipe exits into two 2 ½" polished stainless mandrel pipes that enter a SOLO free flow true X design, ceramic and glass packed, polished stainless MACH muffler. Tails with stainless tips completes this rear section.
  • Sound- Quieter performance is what this system offers. A beautiful smooth sound.
Sound Clips and Videos
Saturn Sky Redline MACH Exhaust Kit- $653
Shipping- $100 (most of the USA and Canada)
Please send me a PM for questions, concerns, or order inquiries.
ID:	31230   Click image for larger version
ID:	31231   Click image for larger version
ID:	31232   Click image for larger version
Name:	Saturn Sky redline pic for pag 90.jpg
GOINGSOLO2 is offline
post #2 of 23 (permalink) Old 06-08-2010, 05:07 PM Thread Starter
GOINGSOLO2's Avatar
Spring and summer are here! Hook up your Sky with one of our great exhaust kits be the one that turns heads! You can reach me anytime with questions or to order at 516-655-9002. You are now also able to order through our website at : Welcome to Solo Performance : For Mufflers, Exhaust, Stainless Steel Tubing and Mandrel Pieces. Pics, Video, Installation.....Order Online.
Steve
post #3 of 23 (permalink) Old 06-13-2010, 02:43 PM
Johnny-Longtorso's Avatar
Hi guys -
I had my quad-tip MACH exhaust and high-flow cat installed this weekend at NASSM.
It's sounds awesome, and the fit is PERFECT.
Unfortunately on entering the freeway we pitched a P0420 code.
Is this typical with the high-flow cat? I've seen a few posts relating to Magnaflow and other brand kits, but never the Solo kit.
And suggestions appreciated.
Your highly detailed mods signature, while impressive, really really screws up Google & site searches.
Johnny-Longtorso is offline
post #4 of 23 (permalink) Old 06-14-2010, 08:25 AM Thread Starter
GOINGSOLO2's Avatar
First off, thanks for supporting SOLO. In regards to your CEL, make sure that the 02 extender was installed in the rear most 02 bung. Installation in the wrong bung will cause a code...some customers have even forgotten to install the 02 extender right off the bat. If this all checks out, then make sure you have no leaks. I leak will also set off a code...everything should be torqued to 60ft/lbs. I hope this helps you.
Steve
post #5 of 23 (permalink) Old 06-17-2010, 09:16 PM
Hmm - was an extender supposed to be included or was that something I needed to get separately? (I did not have one)
Is it absolutely required or can the stock harness be pulled to "work"?
I will also ask the DDM guys to comment on the sensor connection.
post #6 of 23 (permalink) Old 06-18-2010, 10:19 PM Thread Starter
GOINGSOLO2's Avatar
The extender is not a wire....it is about a 2-3 inch stainless bung extender that screws into the 02 bung. The 02 sensor then gets plugged into that. They come with all kits, and are sometimes thrown away by accident because they are a smaller item. You can not pull the stock harness...you risk damaging the wires and will not get much more slack anyways. I hope this helps.
As a kind side note...nothing personal at all, but I deleted the posts about the signature stuff...it was way off topic and not appropriate in a vendor's product thread.
And now, back to our SOLO products
post #7 of 23 (permalink) Old 06-19-2010, 10:24 PM
DDM installed a high flow cat in my Sky. I am throwing the same code. Dave is going to reprogram my ECM , which is supposed to take care of the problem.
Bought new 2008 Carbon Flash, 2.4 , 5 speed DDM SC II, DDM Backbone, DDM Pro Beam. DDM chrome valve cover, Wind Restrictor Lighted door sills, ICS, FE3 shocks, springs, swaybars. Energy bushings. Redline exhaust and rear valance
Ivan Love is offline
post #8 of 23 (permalink) Old 06-20-2010, 08:05 PM Thread Starter
GOINGSOLO2's Avatar
Do you have your 02 extender installed in the correct location?
With a tune, you can turn off the code as a whole.
post #9 of 23 (permalink) Old 06-21-2010, 03:21 AM
rickaf's Avatar
i was having the same problem when I first got this installed just to find out that the extender was not correctly installed.....I got it fixed and now code
rickaf is offline
post #10 of 23 (permalink) Old 06-21-2010, 08:18 PM Thread Starter
GOINGSOLO2's Avatar
post #11 of 23 (permalink) Old 07-05-2010, 02:46 PM
What is the difference between and 02 extender and the 02 sensor?
gordonjj is offline
post #12 of 23 (permalink) Old 07-07-2010, 02:36 PM Thread Starter
GOINGSOLO2's Avatar
The extender is a small stainless piece that screws into the bung. The 02 sensor actually screws into the extender. The extender is used to take the 02 sensor farther out of the exhaust stream...it keeps the CEL off.
post #13 of 23 (permalink) Old 07-23-2010, 07:02 PM
Junior Member
what about kooks, or corsa exhausts are they any good?
wileynote is offline
post #14 of 23 (permalink) Old 08-02-2011, 11:57 PM
O2 Extender
can you SOLO guys throw a pic of what the O2 Extender is supposed to look like? I have all the parts somewhere in my garage...
If I did throw it away, can I buy another one?
2008 SKY RL
Fujita CAI
GMPP Turbo Upgrade
SOLO Mach 3" Cat-back Exhaust
Asian Sky RL is offline
post #15 of 23 (permalink) Old 08-03-2011, 07:18 PM
BLACK_SKY's Avatar
Ordered ! Thanks Steve.
I'll let you know how it turns out.
I'm Psyched !!
BLACK_SKY is offline
  Saturn Sky Forums: Saturn Sky Forum > Vendors > Solo Performance
