Installing GT Manufaktur Gas spring for trunk lid - Page 5 - Saturn Sky Forums: Saturn Sky Forum
Skyroadster.com Merchandise Click here to visit the Skyroadster.com store
post #61 of 74 (permalink) Old 09-27-2017, 03:14 PM
Taz
Taz's Avatar
Quoted: 73 Post(s)
Originally Posted by TerryJ View Post
Has anyone had a problem with the lid moving out of place when installing this according to instructions? I plan on marking its location with tape just in case, but just wondered if just snugging up the bottom bolt after installing the bracket is sufficient to hold the lid while taking out the top bolt to swing the bracket into position. Thanks, TerryJ
I've had mine on for a few years and no issue with the deck lid moving.
Taz is offline
post #62 of 74 (permalink) Old 09-28-2017, 07:58 AM
Quoted: 176 Post(s)
LOL
Its a small strut. It does not apply enough force to move the mounts that are properly torqued. The trunk lid gets a LOT more asymmetric force put into it when you lift it from one side and slam it shut from the side.
Rob the Elder is offline
post #63 of 74 (permalink) Old 09-28-2017, 11:35 AM
TerryJ's Avatar
Quoted: 36 Post(s)
Trunk lid gas shock install
I guess I must have asked the question in the wrong way. What I meant to ask was, During the install of the bracket that uses the original bolts that attach the lid to the hinges, you take the bottom bolt out and attach the new bracket that the gas strut ball goes on. When you tighten this lower bolt back up enough to still allow the bracket to rotate into position at the upper bolt location (now removed) does the lid try to move or change position when you rotate the bracket into position so you can reinstall the upper bolt? I hope this clears up my original question. Thanks, TerryJ
"Man cannot live by Bread alone, He must have Peanut Butter"
TerryJ is offline
post #64 of 74 (permalink) Old 09-28-2017, 02:12 PM
Quoted: 176 Post(s)
No .
post #65 of 74 (permalink) Old 09-28-2017, 05:13 PM
TerryJ's Avatar
Quoted: 36 Post(s)
Originally Posted by Rob the Elder View Post
No .
Thanks, That takes a little of the stress out of the install. TerryJ u
TerryJ is offline
post #66 of 74 (permalink) Old 10-08-2017, 05:42 PM
TerryJ's Avatar
Quoted: 36 Post(s)
Gas Shock lift deck lid install
Easy install. Deck lid now pops open and raises by itself like it should. I would recommend this to everyone having a problem with the lid.
TerryJ is offline
post #67 of 74 (permalink) Old 10-09-2017, 06:57 PM
Quoted: 91 Post(s)
Ordered from GT Manufactur last week. Have no idea how long it takes to get here from across the pond.
2007 Silver/Red Sky Redline
Huff is offline
post #68 of 74 (permalink) Old 10-09-2017, 09:22 PM
SaturnSkyRedline2015's Avatar
Quoted: 87 Post(s)
The shipping is actually quite fast.
SaturnSkyRedline2015 is offline
post #69 of 74 (permalink) Old 10-10-2017, 09:58 AM
TerryJ's Avatar
Quoted: 36 Post(s)
Gas Shock lid Assist
Had mine in about a week.
TerryJ is offline
post #70 of 74 (permalink) Old 10-11-2017, 10:01 PM
Quoted: 91 Post(s)
Just got mine today. Ordered it on the Oct. 4th so one week. I know what I'm doing this weekend!
Huff is offline
post #71 of 74 (permalink) Old 10-18-2017, 11:48 PM
TerryJ's Avatar
Quoted: 36 Post(s)
Gas assist shock install
How did your install go Huff? Thanks, TerryJ
TerryJ is offline
post #72 of 74 (permalink) Old 10-19-2017, 06:57 PM
Quoted: 91 Post(s)
Very easy, quick install. Photos on these forums helped quite a bit. Only tough part was snapping in the retainer clip onto the strut ball. It has a tiny pin hole that the clip inserts thru but that hole ends up on the back side facing away making it impossible to see. Just kept feeling around until it popped into place. Started with the default A2 setting which worked but I ended up moving it to B3 which opens the lid much better and keeps it up even in a breeze.
Rather expensive but this kit works, easy to install and looks factory.
Huff is offline
post #73 of 74 (permalink) Old 10-20-2017, 12:07 AM
TerryJ's Avatar
Quoted: 36 Post(s)
Gas shock install
Yea, the retaining pin can be a bear. I just pre installed the ball on the shock with the locking pin already in place and just bolted it in on the top mount with an open end wrench and socket. Made it a lot easier to install. I also used the B3 position, much better. TerryJ
TerryJ is offline
post #74 of 74 (permalink) Old 11-20-2017, 10:58 PM
Frank's Avatar
Quoted: 8 Post(s)
Ordering this week...question for those that already installed. Does this prevent the trunk hinges from contacting the rubber stops when the trunk is fully opened? Ive had a bad experience with the hinges hitting these with force, bending the brackets and placing dimples in the rear bumper. Id like the trunk to stop its travel just shy of these rubber stops. Is this possible with this strut? Thanks!
Frank
Valley Forge, PA
Frank is offline
  Saturn Sky Forums: Saturn Sky Forum > SKYRoadster News & Polls > Skyroadster.com Merchandise
« Sky hat | Sky Watch »
