1 - 20 of 41 Posts
Hey guys!
As I have dug through the forums here and around the web, I am posting this and hoping I haven't missed a previous resolution to this problem. I have owned an '08 Redline for about 3 years now. Since the day I bought it, the radiator fan has never worked. As you can guess, this makes for some nerve racking drives in rush hour traffic. When the car is in motion (anything above 30mph), my coolant temps range from 194-199. Whenever I stop/slowly move for any extended amount of time, my coolant temps rise steadily and when not kept in check, will eventually trigger the overheat light and chime. I might also mention that my air conditioning does not work unless the car is moving (wind turning the radiator blades.) If the A/C is left on for a few minutes at idle, fog will eventually come out of the vents. I have had the fan tested by direct connecting to the battery and it is functional. From what I can gather from my extensive searching, this issue is caused by a faulty "Fan Control Module." Though I have searched, I have not been able to find any reference to the part or its part number on the web. Has anyone had the same issue or can you provide me with the part number for the "fan control module?" Can the module only be replaced by purchasing the entire shroud assembly?
Check fuse #1.
If you have jumped it off or used it to jump someone else off it will be blown and have the exact results you are experiencing. Ask me how I know. LOL
Discussion Starter #3
Check fuse #1.
Thanks for the feedback...I will give this a go in the morning. It would be insanely awesome if this is the fix for me! Will update:cheers:
Another way to test if you are getting power to the fan controller is to use a test lamp and see if you have power on the outer stud on the under hood fuse block. The one with the red cover to the motor side is the battery. use the test lamp on the one nearest the fender, you will have to pull the top off of the fuse block to access it. If you have power at the fuse and none at that post you could have a fuse block problem. It may also require you to have the ignition key in the "on" position to test it
Just in case you don't know the 2.4 engine has a different fan and will not work with the 2.0 engine.
Discussion Starter #6
Sadly, the fuse was not the issue, but for $5 it was definitely worth a shot. I read on the Solstice Forum (that coincidentally enough, HoosierGXP had assisted with as well) that there were folks on the forums that had extra controllers. The author of that thread was lucky enough to find one, so here goes a shot in the dark...Anyone have an extra fan control module they'd wanna part with? It is annoying me to no end that you can't just buy the controller haha :banghead:
Welcome to the furum.
Since the day I bought it the radiator fan has never worked.
:eek: Can't imagine that you haven't blown something before now.
Were you one of Santa's helpers up at the North Pole?:D
Discussion Starter #9
The fan is set to come on at around 225 deg. I have never even got close to that and my fan has never had to kick on. Your car is fine.
I wish this were the case but my fan doesn't come on at 225 or 250 for that matter or when the A/C is turned on.
Have you disconnected the plug from the fan controller, and with a test lamp, seen if you have power to that point. The fan kicks on by a signal to the controller, so there should always be power at that plug. Don't discount that the fan motor it's self can be bad. I am not sure if you can "force" the fan to work by bypassing the controller but if I get a chance today I will try it on a 2.4 fan motor that I have. I did have a controller for a 2.0 but I sold it to another member here on the forum who was having a similar problem.
It is possible to force start the fan. Verify that you have power and ground to your jumper. remove plug from controller. Inside you will see 3 pins the center pin is the signal pin don't connect anything to it. Look at the plug or the back side of the wiring on the controller you will see the wiring entering there. The red is the hot and black is the ground. Again, "DON"T" connect anything to the center pin that could damage the controller. The fan should run with the hot and ground wires making contact. You can try also to get your power and ground right from the plug you removed this will verify that you have power and ground to that point.
Hey guys!
I've dealt with this exact issue. The dealer replaced the ECM under emissions warranty along with the fan control module and that fixed it. The fan control module I believe is attached to the fan, so when you buy a new fan, you get a new module. I tried looking for that little piece by itself and I could never find it.
Hoosier...thanks for the reply and your assistance! I will give this a go after work! :cheers:
What ever turned out from this, M3TALLUM? I'm having similar issues with my '08 Redline. The temp climbs when at stops but when I drive, it cools back down. At around 217-219 F, I opened the hood to see if the fan was moving and it wasn't.
May need a fan replacement. I keep meaning to grab that old fan of Jgasser and see if I can rebuild it. It may be the brushes are worn out or the control module is bad. Either way, unless you're experiance at rebuilding electrical motors or can get a spare relay, you need a new assembly. Now, I believe someone on here mentioned they found ford uses the same relay and you can get it as a seperate unit from them. You may need to search for that one though.
Assuming that's the issue, what would the ballpark figure be for this from the dealership?
To replace the whole assembly for my NA it was $331.34 for what they called a "shroud", when it really should be called the "Cooling Fan Assembly", part number 19130491(and yea I know I over paid for it big time), labor was $260.00, so total was $591.34. I also had a discount coupon worth $153.13 off the part and labor. So my final cost was $438.21.. Tech comment was, "replaced cooling fan motor"...:willy: I don't know if it's the same part number for the R/L..
OP hasn't been logged on since July 1 2014 and only has 5 posts, I fear we might never know his final results since he rarely logs on and posts even less...:dunno:
1 - 20 of 41 Posts
