1 - 15 of 15 Posts
My 2007 Base Sky restoration continues.....this car was not supposed to be a restoration project. :(
I pulled off both front fenders for an inspection and clean-up. This is what I found when removing the battery. There is NO rust anywhere else on the body or other painted framework so I assume this is the result of an previous unchecked battery boil-over that went on for some time. Making matters worse was the damage to the underside of the fender and wheel well under the battery, creating the perfect hole for street water to spray up at the battery tray.
The current battery is 1.5 years old and is in great condition with no boil-overs and holding a charge well, but I have yet to check the alternator output voltage.
I ordered a new battery tray shown in black at a cost of $52.00. I debate on how to attach it, screw-on or OEM weld-on. I lean towards "screw-on" even though the attachment flanges are not ideal for it. I welcome your comments.
112120
112121
112122
112123
I think you are going to have to cut away all of the bad, and evaluate it then. A compromise would be to weld a bracket to the new battery tray, then bolt that to the car.
Keep the obvious in mind: Batteries aren't light, and you don't want it to come loose.
Discussion Starter #3 (Edited)
Good point! Thanks for that.
This is my thought as of late.
Where the original battery bracket steel and weld is still solid and reliable, I will consider trimming it to create mounting tabs. I will make new brackets where needed and bolt it all together. Once assembled, I will then take it all apart and prime & paint everything. After final assembly, then follow up with another coating of primer and paint over bolts and all for extra protection. I figure all that extra paint will also help prevent the hardware from coming loose over time.
It would be great if the vehicle frame is thick enough for reliable tapping of new threads for bolt-attachment. I don't want to go crazy drilling holes (or drilling huge holes) in the vehicle frame. I will have to use common sense for the right balance between frame integrity and reliable battery bracket attachment.
If I was a good welder, I would have considered that attachment method.
You are definitely on the right track.
Here is an option if you need it. Not the least expensive the first time because of the tool, but very effective:
I get them here: McMaster-Carr
Discussion Starter #5
Very interesting John. Thanks for sharing that threading option. I will keep that in-mind during my evaluation.
Discussion Starter #6 (Edited)
Well, I started removing the old battery tray and concluded the remaining welded material for mounting to was not trust worthy so I cut it off and ground it all smooth. At this point in time, I seek someone to weld the new tray on. I got in contact with one mobile welding service so far and they have a minimum charge of $250....ouch! If they all are like that, I will consider bolting on sturdy "L" brackets to attach the new tray.
Here is where I am tonight. It would also be nice to have the lifting point reinforce-welded.
One thing to note is the metal piece seen to the right, welded to the frame. It once went all the way to the left-side black caulk. It was rusted so badly that I removed it by hand in places. I had wondered if it was a frame reinforcement, so I looked at the driver side, but nothing is there. So then I wondered if it was an acid boil-over shield. If it was, it surely was minimal in coverage and the frame behind it had rust too, though not nearly as severe.
112134
Here I am holding the new tray in-place to see the general fit. It's a good fit.
112135
With all 4 fender liners out right now for general cleaning and inspection, I can see the rest of the frame and body is rust free, in very nice condition. It was a southern car. All the rust was limited to the battery area, introduced and accelerated by a battery acid boil-over years ago. I think it was aggravated further because the fender had a hole in the bottom allowing for tire splash up in the area.
112136
A bit off topic, but since I mentioned the hole in the fender, here is my patch. 4 stainless screws and an entire 2-part epoxy kit holds it on securely. The black material is a piece of the original right front fender liner that was badly damaged. I replaced that too.
112137
I cut slits into the material so it would follow the natural curve of the fender when screwed on. Once shaped properly mounted with screws, I glued the tabs using a 2-part epoxy. It seems to work well.
112156
I did not notice the large hole when buying the car so I figure this will work until I can locate an affordable good Ming Blue replacement. The stainless screws will get painted Ming Blue as not to draw attention. What looks like missing paint is actually a reflection from light fixtures.
112138
Discussion Starter #7
The cost for a mobile welding service is a fortune, $250 minimum charge. So I called a local shop that is exactly 2.5 miles away. They told me $50 if I can get the car there. So this is what I came up with using 4 reusable shopping bags. They hooped around the hood stop and are quite strong. My battery is not that heavy given it's size. I have to confirm the front tire won't hit it when turning which I think will be fine since the battery is in the proper position relative to the car.
112186
Looking at the picture, I just realized how fitting the statement is on the bags.
My interior is gutted so on the passenger side, I am equipped with everything needed to setup the car like this for them at their shop.
112187
I agree, the saying on the bag is priceless. Hopefully the local shop can fix it up and looking forward to the final result.
Discussion Starter #9 (Edited)
Today I drove the Sky to the welding shop with jack, jack stand and tools. Once there I got the car setup and ready for the welder. It took him 20 minutes of prep and welding. His boss charged me $1 per minute, so the bill was $20. I tipped the welder an extra $10.
112200
After I got the tire back on and the car off the jack, I then proceeded to mount the battery on the new tray, but wait, what's going on here? I could not mount it on the tray quite right, so I added extra security with a bunge cord and drove the drive home. Back at home, I realized what happened. It turned out that the mounting/welding tabs of the new tray caused the position of the tray to tip a tad down towards the rear of the car. That caused the top of the battery to contact that 45 degree square stock frame member preventing it from seating properly on the tray. A little adjustment of the tray via a pipe and crow bar, and it's all good. It's not OEM perfect, but surely is a good job done.
The lesson learned is that I should have cut a block of wood to use as a spacer between the battery tray and that silver painted rear wall to assure the proper distance during the initial tack welding. So be sure to keep that in-mind.
I brushed on a coat of Rustoleum primer over the tray and affected frame. Soon to follow are 2 coats of gray Rustoleum paint. Drying time makes this a 3 day painting project.
Looks good. Congratulations.
Discussion Starter #13
do you have a source and part number for that tray. I have the same issue now.
The tray is a GM part, ordered from my local Chevy dealer. Scroll up and review the pictures for the part number.
A word of caution when welding the tray to the frame. The angle of the platform is very sensitive for the battery to fit. Pitched down and out, the battery interferes with the fender. Pitched too far inward and the battery interferes with that silver painted 45 degree frame support. I strongly advise to take a measurement of your rusted battery tray and do your best to maintain the same platform pitch.
That caught me off guard. My battery interfered with the 45 degree bracket. I ended up bending the battery tray side supports outward to pitch the platform away from the 45 degree frame support. You can see my adjustment if you compare pictures closely.
Discussion Starter #15
Great reading. Did you every figure out what the other piece of metal was that laid on the frame?
No, I never did figure out the purpose of the welded piece of metal was for. I was near impossible to to figure out with so much material missing. Maybe someone with an original battery tray that was not rusted might be able to figure it out, the next time he has his right front fender off the car to replace his battery.
1 - 15 of 15 Posts
