1 - 2 of 2 Posts
· Registered
2007 Base Roadster, "Stock" for the most part, but with lots of interior illumination changes
I understand the Redline 2.0T has the fuel filter inside the fuel tank.
Is this also true for the 2.4L Base Roadster?
Is the fuel filter integrated with the fuel pump and sending unit for the fuel gauge?
Is it a "Replace One, Replace All" assembly?
I found this picture on the internet, not sure if it applies to both the 2.0L turbo and the 2.4L n/a.
Gas Art Street light Machine Office supplies
I also found this one that looks different, having extra parts but lacking the black block float with the arm.
Gas Electrical wiring Machine Electric blue Cameras & optics
· Registered
I replaced my in-tank pump for the 2.0 a couple of years ago. Having the old pump, I took it apart. There are two filters in the pump. A sock/screen that attaches to the inlet/bottom of the actual pump and a finer canister filter that surrounds the pump. From here it goes up to the engine fuel rail, no other inline filters.
The other interesting thing is the fuel filter is always cooled by a bowl of fuel, which is fed by a Venturi on the bottom of the plastic bowl. So unless the fuel tank is actually empty, the pump will not overheat.
Automotive lighting Personal protective equipment Automotive tire Fashion accessory Automotive wheel system
Wood Gas Tints and shades Flooring Metal
Liquid Fluid Tin Water Drinkware
1 - 2 of 2 Posts
