SkyMan 07 said:if you will look at the standard featurs a content alarm is included, it blows the horn and flashed the lights if the door or trunk is opened without either the key or the remote entry...
Just a little follow up. IF the "content alarm" is set via the Remote Keyless Entry "RKE", the horn will give a few pre chirps before going into full alarm mode if the DRIVER'S SIDE door is opened (say the window was down and someone just pulled up on the doorlock thing and then opened the door, or instead of using the RKE, someone stuck a key in the door to unlock it).MRSVIPER said:OK, this is probably a stupid question, but here it goes...Are the sky's equipped with an Alarm System?![]()
dmbdlatc said:Just a little follow up. IF the "content alarm" is set via the Remote Keyless Entry "RKE", the horn will give a few pre chirps before going into full alarm mode if the DRIVER'S SIDE door is opened (say the window was down and someone just pulled up on the doorlock thing and then opened the door, or instead of using the RKE, someone stuck a key in the door to unlock it).
If the PASSENGER'S side door is open with the content alarm armed, the alarm will sound instantly.
Keys: They have little electronic transponders in them. You can have a key cut to match you original key and it will unlock the door. It will also go into the ignition and turn the key, BUT THE CAR WILL NOT START UNLESS THE NEW KEY HAS BEEN PAIRED WITH THE CAR. This is a simple process, simply start the car with a working key (one that the dealer gave you when you bough the car), then turn off the car and insert the new key into the ignition and turn the key WITHIN 5 SECONDS. The car will learn the new key and then start the car.
Well, I'm no expert. But I did what the manual said to do and my 3rd key (extra that I bought from the dealer) works the way I described above in an earlier post after I programed the car to learn the key. I tried the key before I programed it and it turn the ignition, but it would not start the car.Homer said:This car is equipped with passlock, you can not learn keys in the key cylinder. they have to be programed by the dealer. ford keys can be done this way but not GM. Passlock will hold this code for about ten seconds so if the car is started with the working key and then you put a non programed cut key in the ign. it will start but it will not learn to the key. Passlock works with resistance and when the cylinder is turned with passlock a resistance value is sent to the passlock module. you can bypass this buy cutting the passlock wire going to the cylinder(yellow, orange/black, etc). using an ohm meter from the key side of the passlock wire to the passlock ground and turn the key. you will get a ohm value. if you the take the resistor of equal value and connect it to the car side of the passlock wire with the passlock ground the system can be bypassed. you cannot learn a key.
