I've noticed a weird symptom that occasionally happens. I think I've replicated it enough times to say when it happens.
2008 Redline w/ 72,500 miles and an automatic transmission.
When I am leaving my side street at a slow speed (25ish), and I let go of the gas pedal as I near the stop sign, I experience a harder downshift.
It nearly jerks the car for a moment.
The best info I can find so far is this:
www.yourmechanic.com
Does this sound like what it could be?
I have to take out the transmission to replace the rear main seal anyway... so... how hard would it be to replace a downshift solenoid?
Are there any other recommended things I should do to the transmission while it is lowered?
Symptoms of a Bad or Failing Downshift Solenoid | YourMechanic Advice
Common signs that this component of automatic transmissions is failing include erratic or late shifting and the Check Engine Light coming on.
