1 - 4 of 4 Posts
As the title says:
What's the best gear oil for a Sky manual transmission?
I know in most circles (read "Miata or Corvette") there is always a sacred lube that helps make the trans shift smoothly. Sometimes it's hype. Sometimes it's glorious. Has anyone found such a lube for the aisin?
Not for the Aisan, but I used Redline on my Lambo and it improved synchro action quite noticeably. That is what I will eventually put in my Aisan.
Discussion Starter #3
Thanks for the input. Which viscosity of RedLine would you be using? GL-4, since the synchros are brass. Would you go with 75w90?
The miata folks sing the praises of MotorCraft XT-M5-QS in their aisin and mazda transmissions. Makes it an interesting option
1 - 4 of 4 Posts
