I am leaning this way as well. It's tempting to add an aftermarket turbo, but there are issues with that. Its going to be interesting to see the numbers on the RL.skyfan said:I thought about souping up my Sky....CAI, CAT, performance chip etc. You spend $300.00 here $ 400.00 there, another $300.00 and gee, you still need to work on the suspension.Maybe you pick up 15 or 20 HP. I decided to just order a Redline. I think that makes the most sense.
I inquired about that. They said that the Big Bore throttle body is a stock unit that they have machined to increase the inside diameter and that it works with the stock Sky air box as well as CAIs.illness said:I wonder if the Dual filter Cold air intake will bolt straight up to the big bore...
Report, pleaseYellowSky said:Mine is one its smoother . I LIKE!
Kewl! I'll put it on my upgrade list. My Dual Intake CAI is due here Wednesday or Thursday so I should have it installed for sure by the Key Largo cruise.YellowSky said:well for one it hasnt done that stupid shutter when the car is cold like it use to.. but time will tell if it does... its got a lil more pep now. i think it runs a little bit smoother..
Any difficulties putting it on? It seems like it would be a pretty simple mod.YellowSky said:Mine is on its smoother . I LIKE!
