1 - 5 of 5 Posts
So far I havent had to bleed the cooling system, but thought I might get ahead of the problem by installing the self bleeding valve in the hose.
Which hose, and which way round. I have already ordered it from GM
Are you referring to the check valves? I don't think I've seen them called bleed valves, but they may have been.
There are threads with pictures about installing the check valves.
Discussion Starter #5 (Edited)
To find them on Ebay it took that name. You can call them "Mary" but then you wont find them on EBay.
Thank you SlyBob good references.
1 - 5 of 5 Posts
