Running higher boost? Simple upgrade for extra security.
DDMWorks T-bolt Clamp kit for the 2.0L LNF
This is a set of 6 T-bolt style clamps for the Solstice GXP / Saturn Redline Turbo, which replaces the weaker factory worm drive clamps on the charge tubes. This kit is recommended as extra insurance for cars running more boost than stock, as the T-bolt clamps provide more clamping force than the worm drive clamps found stock.
PRODUCT DESCRIPTION:
On the car you will find that there is 6 worm drive hose clamps, these clamps have been known to leak at stock pressures, and at higher boost pressures can really be put to the test. We have put together a simple kit of the 6 hose clamps that you need to replace the worm drive clamps with the higher strength T-bolt clamps, giving you extra peace of mind when running higher boost. No special tools are required to swap the hose clamps and installation time varies with experience.
$24 for the set of 6 T-bolt clamps
Product Link:
DDMWorks Solstice Products
Product Link:
