61 - 65 of 65 Posts
No, no you don't. Just as you have admitted before:rolleyes:
And it wasn't to hassle you, it was to prevent other people from running into the same problem as you have.:thumbs:
If you really read my responses I only admitted that it MIGHT be better, but that I didn't think it was that big of a deal. Seems you must push as hard as you can to make a point you have already made several times though!
Do you need to continue to bring it up again and again? You do realize that others can read more than just the last post, right?
Jim :cool:
Installing vavles.
Great post and the hose off the end.
just changed the oil in my 08 sky,pretty easy.dailer changed it last 3 times,with leaks the last time.Took it back twice to get it stopped.
based on the links for the drain plugs I should be getting a 1/2"-20 correct? Looks like the 5/8" is just the nut that sticks out of the opening.
wow ive never heard of these vavles before. ima have to try them out, looks like it makes life much cleaner. :)
61 - 65 of 65 Posts
