Don't know. I'll pay more attention. Maybe I have a lazy clutch foot.GMguy said:Are you sure you're pushing in the clutch completely before the car stops?
GaryH said:Has anyone else noticed something strange when the engine drops back to idle? Like when you come to an intersection and push in the clutch the engine seems to stutter for a second as it drops back to idle.
Not mine...GaryH said:Has anyone else noticed something strange when the engine drops back to idle? Like when you come to an intersection and push in the clutch the engine seems to stutter for a second as it drops back to idle.
brentil said:If you have the AC on it's more apparent until the car is warmed up. If the AC is off you'll notice a slight RPM dip but not as much.
Good point to list the octane rating with the problem.SkyHi07 said:Mine did it with the 92 Octane. It doesn't do it with 87. If you are running higher octane, I don't think the car can burn it off fast enough.
Man,, that should start all the techs going. Mine runs just as good with 87 as 89, or 92, so I have been burning the cheaper stuff..... Wait,,, none of it is cheap anymore!
