😆 Best laugh I've had in days...Thanks!I want nice and stiff but at 76...it is difficult at times. LOL They do sell a cream but must be applied by a 20 yr old.
Would like some quality mounts too. OEM ones are crap. Mine were both broken after 70,000 km. I have replaced them with made in China crap, which are probably not going to last for long either.Anyone have any good leads on polyurethane engine mounts?
I can get OEM ones for $20-40 each. I don't want OEM. I want nice and stiff.
It gets too serious at times...need some humor😆 Best laugh I've had in days...Thanks!
Have you looked at many of the original factory parts? Made in China. That's where you original mounts may well have come from. Things like the wheels certainly did.Would like some quality mounts too. OEM ones are crap. Mine were both broken after 70,000 km. I have replaced them with made in China crap, which are probably not going to last for long either.
Resistance is futile i guess.Have you looked at many of the original factory parts? Made in China. That's where you original mounts may well have come from. Things like the wheels certainly did.
So, as i understand, it is not for Opel GTs since they all have the torque arm?I found a poly transmission mount!!!!!
Pontiac Solstice Saturn Sky poly RACING performance Transmission Stiff Mount AR5 | eBay
Will fit any Solstice and Sky models if it DOES NOT have the torque arm mount. Will fit ALL 2006 Solstice models because torque arms were not used in 2006. The torque arm mount is a beam like structure that solidly connects the transmission output to the rear differential.www.ebay.com
You are correct.So, as i understand, it is not for Opel GTs since they all have the torque arm?
Kappahaus.com has some.Anyone have any good leads on polyurethane engine mounts?
Hey Talis....you didn't happen to race N2K3 online back about 10 years ago did you? The reason I ask is I raced in a league, and we had a guy that went by the same name...just curious.Kappahaus.com has some.
If you get kilmat or something similar and put it on your floor, it'll take care of 75% of most of those squeaks. When I did my complete stereo redo, I did this. 2 boxes (40lbs) of kilmat put on the floor and some of the doors and backwall.If changing engine mounts from rubber to polymer, is there a noticeable increase in engine vibration? There are enough rattles and such. I would be concerned of amplifying them.
From personal experience polymer mounts last longer, enhanced road feel and a slight increase in road noise and vibration. On some applications we did notice a squeak and they did cost more than the rubber mounts.If changing engine mounts from rubber to polymer, is there a noticeable increase in engine vibration? There are enough rattles and such. I would be concerned of amplifying them.
Dude. I love it. That's going on the list.If you get kilmat or something similar and put it on your floor, it'll take care of 75% of most of those squeaks. When I did my complete stereo redo, I did this. 2 boxes (40lbs) of kilmat put on the floor and some of the doors and backwards.
