1 - 3 of 3 Posts
I stumbled on TSB 08-03-16-001B (copied below) for a 2008 Sky which includes TPMS. Is there one specifically for a 2007 without TPMS? I'd like to have a paper copy with me of the right TSB when I go to the dealer. When done, I want to make sure I can disconnect the main battery for an extended period of time without messing up the FOBs.
For those who are acronym deprived.....
TSB = Technical Service Bulletin
TPMS = Tire Pressure Monitoring System
TSB ----------------------
Your Vehicle: 2008 Saturn Sky L4-2.0L Turbo Vehicle » Technical Service Bulletins » All Technical Service Bulletins » Keyless Entry/TPMS - Fobs Inop/TPMS Incorrect Readings Notes Keyless Entry/TPMS - Fobs Inop/TPMS Incorrect Readings TECHNICAL Bulletin No.: 08-03-16-001B Date: July 31, 2008 Subject: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes On All Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR) Models: 2008 Chevrolet Cobalt, HHR, Malibu 2008 Pontiac G5, G6, Solstice 2008 Saturn AURA, SKY Supercede: This bulletin is being revised to update the Important statement to reflect the new direction to no longer contact TCSC. Please discard Corporate Bulletin Number 08-03-16-001A (Section 03 - Suspension). Condition Some customers may comment that the key fobs are inoperative or that the TPM system is showing dashes as the reading for all four tires. Technicians may find DTCs C0775, C0569 and B3105 set simultaneously in the RCDLR module. In addition, the technicians may find Tire Pressure Monitoring sensors are unable to be programmed to the vehicle by adding or releasing pressure to the tire while the vehicles in the TPM learn mode. Cause These conditions may be caused by the following: ^The RCDLR may lose its transmitter and tire pressure monitoring data from its memory if a low voltage condition occurs on the vehicle. ^The ability for TPM learning by adding or releasing pressure to the tire has been disabled in the RCDLR. Correction Reprogram the RCDLR with an updated software calibration to address both issues listed above. This new service calibration is available on TIS2WEB using Service Programming System (SPS). As always, make sure your Tech 2(R) is updated with the latest software. Important: If the Tech 2(R) could not establish communication with the RCDLR AND the programming event ended with error, attempt to reprogram in Service Programming System (SPS) by selecting "Remote Control Door Lock Receiver (TSB 08-03-16-001) with E4399 error Pass Thru Only".
The TSB for the key fobs and TPMS was for an issue in 2008. 2007 was not an issue. Nor is 2009. 2008, after having the TSB done, should no longer be an issue.
Got it?
1 - 3 of 3 Posts
