1 - 1 of 1 Posts
I recently installed a new ATK LNF engine in my '08 Redline because my old engine had a blown out piston ringland. Some of the parts shown/listed are brand new and never installed, some have less than 1,000 miles on them because I had my old engine repaired just prior to it dying, and some are from the original engine (130K miles).
Brand new:
  • SOLD OEM BorgWarner K04 turbo taken off from the new ATK LNF engine (I already had a big wheel turbo) SOLD
  • AC Delco water pump (P/N 252-821 or 89036356) and gaskets plus Fel-Pro ES 71282 gasket set
  • Hawk Street 5.0 front brake pads (HB 524B.740)
  • Valve cover with gaskets (this was taken off the ATK engine and replaced with my old polished valve cover)
Almost new (less than 1,000 miles unless noted):
  • High pressure fuel pump (HPFP) with metal bracket and foam noise supressor.
  • Timing chain kit (Cloyes 9-4201SX Timing Chain) and balance shaft kit (Cloyes 9-4202S Balance Shaft Kit)
  • Throttle body (6K miles)
  • Ignition coils (set of 4)
  • Variable valve timing solenoids (VVT) - intake and exhaust
  • Mass air flow (MAF) sensor (GM 15865791) - (10K miles)
  • Turbo heat shield (5K miles)
  • Hawk Street 5.0 racing compound front brake pads - less than 100 miles. For you autocrossers who haven't upgraded your brake size. I ordered regular street pads but the ones they sent me squealed loudly. When I sent photos of the backs of these pads to Hawk, they confirmed I was mistakenly sent pads made from racing compound, sent me street pads, and told me to keep these).
Original (130K miles)
  • Variable valve timing solenoids (VVT) - these still work well. I bought new VVT's (described above) thinking my old engine issues might be related to them, but nope.
  • Intake manifold
  • Fuel rail
  • Left and right engine motor mounts (mechanic says these are in great shape)
  • Leaking turbo - good for making core exchange
  • Miscellaneous turbo-related piping, nuts, bolts, bracket and clamp
  • Catalytic converter
  • Right passenger side hood latch (GM 25785136)
I'm located in Orange County, California. Any reasonable offer considered...PM me.
FYI, to send a PM (now called starting a conversation) to a forum member:
  1. Click your member icon at the top right of the page. (It is the square that says "Account Details" when you hover over it.)
  2. Click on "Conversations" in the drop-down list
  3. Click on "Start Conversation" at the top right of the page that opens, just under your member icon
  4. In the box labeled "Recipients" start typing TopDown13 (or the name of the member you wish to message)
  5. When the name of the member you want to message shows up in the list, click on it
  6. Type a message title in the box labeled "Title"
  7. Type your message in the big box below that
  8. Click "Send Message" at the bottom of the page.
0207201758.jpg 0207201734b.jpg 0207201733c.jpg 0207201735_HDR.jpg 0207201737f.jpg 0207201737d.jpg 0207201737b.jpg 0207201738a.jpg 0207201738b.jpg 0207201758d.jpg
1 - 1 of 1 Posts
