1 - 19 of 19 Posts
Ok ... everybody check out your fuel door ... I've seen two Skys up close and personal ... mine and 1 at the dealership and both have the same minor flaw ... its "almost a paint drip" on the bottom edge of the fuel door ,,, anyone else have this "almost flaw"?
Its like the fuel door was painted in the vertical position ... and as gravity pulled the paint down it dried ... and there is a hint of a drip hanging from what is the bottom edge.
OBTW, did I mention these cars are beautiful?:thumbs:
No drip on ours.
Actually one of the first things I checked as I had that on another car that had a round fuel door. Nope -- mine is OK
Mine is OK, but as of today I can't get it to close right. It's probably from my recent habit of pumping my own gas to balance out the cost of 93 octane. I think it's broken, and I definitely should've known better. :(
I had this problem too, but then I noticed that the black plastic tether on the cap has to be moved around a bit to prevent it from pushing back on the door.
No drips here looks good !
I have a few drips on other parts of the car. How many of you still have the little rubber nub that the fuel door rests against when closed??
mine fell off during the first week!!
I am droopyless.
I tried playing around with the tether, but my gascap also doesn't want to stay closed. I push it in and turn it, then it just pops back out. If I turn it around and around and around, eventually it'll stay closed.
In earlier threads, when I mentioned that I have horrible luck with all cars, this is the kind of stuff I meant. Stuff that seems absurd and doesn't happen to anyone else. I have some sort of bad automotive karma. I'm going to try to take it in to a dealer in Maryland when they open in 4 hours.
Just turn it to the first click.
Mine is fine but I find it interesting that they recessed the fuel inlet so far in on the side of the car that If you are not careful fueling the car there is a chance of the bottom of the automatic fuel shutoff handle hitting the paint. I hold the gas nozzle level to keep the handle off the paint!
Baby Your Baby!
no drips here.
1 - 19 of 19 Posts
