21 - 40 of 40 Posts
Excellent find Sky Pilot! If I can't pull mine out of my car I can't order it!
--Strike that. OEMcats is a referral service that'll show you a list of parts distributors who carry the part. No parts themselves. I checked each one provided and they're all showing unavailable. Well, I'll just have to go fishing for my old part!
Let me save you all a lot of trouble. After looking on line at auto parts stores, in amazon, on ebay, and more, I found this simple little part at NAPA locally. It was ON THE SHELF and cost $4.00 for each side and the man was nice enough to clip them on Several of the references above are wrong. Try this, I just did it ONE hour ago. NAPA part # 735-2786. Get the right number, a number of these clips are out there and they are different sizes. Once on the car, the metal part being discussed above simply pushes into it.
Discussion Starter · #24 ·
Got the problem fixed and solved. I ordered a pair of Silverado tailgate handle rod clips, one left (red??) one green (right). Use some needle nose pliers to rip out the remains of the original clips, pushed the new ones into place and then threaded to cables thru. Slick as a whistle.
Discussion Starter · #25 ·
Update. The right clip is beginning to show stress lines at the "L" angle. Any way, is there a way to adjust the length of the flap cables? The flaps will only open between 70 deg. and 80 deg. so I still have to manually open the flaps, especially the right one, so the top will close.
try bending the brackets that the cable sheaths attach to (away from the flaps)
Discussion Starter · #28 ·
FYI - I discovered that the plastic clips are the exact same critters GM used to connect the latch rods on their pick-up trucks. So, let's see...Seats - base Covertte. Tranny - Cadillac CTS. Roof flaps - GM pick-ups. Engine - Chevy Cavalier. I'm surprised they cars still run.
I need the metal piece it clips into! Any suggestions?
Discussion Starter · #31 ·
The clips for top cables are the same one Chevy / GM used for the tail gate latches on their pickups.
Discussion Starter · #32 ·
Okay. I haven't been able to get the flaps to work correctly. So, has anyone had a shop fix the cables and connections so they work right? How bad was the damage? Something to save towards for this spring.
My cable were stretched with no adjustment to be made. I put a piece of rubber around roof pivot shaft under cable to take up shaft. Worked great.
It is always good to know about alternate repairs, thanks.
By the way, you can edit your posts by clicking on the three-dot icon at the top right of the post, then selecting "Edit".
  • Like
Reactions: Ftallman
Discussion Starter · #36 ·
Thanks for the info. Could you better explain where you put the rubber? My Redline is under cover until I can see the grass again.
The cable is attached to the spindle on top pivot. I put rubber or plastic between cable and this pivot point. I remover rubber that i first used (did not hold up) and switched to plastic pipe. You only need about an 1 1/4 wide, i cut it down the middle so i have 2 pieces, one for each side. I attached them with double sided tape to keep in place. Spit plastic pipe with hacksaw before cutting to length. I’ll let everyone know how it works and if it lasts. If it doesn’t i may try metal pipe.
114674
114675
114676
114677
Discussion Starter · #40 ·
As I was raising the top I noticed there was a small hole in the one lift arm. It was where one end of the cable attached. I didn't get a good look as it was dark. Could this possibly be an Allen nut that can tighten the cable?
21 - 40 of 40 Posts
