With the actuator replaced- can you hear the function actually work when you
shift the temperature control from one extreme to another as John has suggested?
If the blend door does not physically function there will be no re-direct of heated
fluid to the core for operation.
The only fuses I think would apply here maybe are- #10 & #16 in the floor box
in the passenger foot well. Both control the Climate Control system. You never know.
They may not be bad but a check and reseat can't hurt any? Try recalibration after
this reset of those fuses. The under the hood fuse box- I think the only ones that would
apply are the fan controls, which you know are good since the car runs at normal temps.
The fan blower motor works for the HVAC controls- you are getting power and fan speeds.
Could the actuator replaced be- bad? Maybe not likely. If it fails to do it's job, opening
the blend door or a fuse reseat- the control pod functions fail to be recalibrated preventing
the flow of warm air to the interior cabin space. The only other thing I can think of is maybe
one of the circuits on the HVAC control board has gone bad- loose solder connection or contact
connection preventing full function or operation.
