Look what I was able to find, just in time for the recall….
Saturn Sky/ Opel GT/ Pontiac Solstice
Ignition Lock Cylinder Removal
Removal Procedure:
1 - Disconnect the negative battery cable.
2 - Disable the SIR system.
3 - Remove the steering column trim cover.
4 - Turn the ignition lock cylinder to the RUN position.
Important: There are two retainers on the ignition lock cylinder. Depress both retainers to remove the lock cylinder from the housing.
5 - Depress the first retainer through the lock housing access hole (2) with a small allen wrench or similar pick-type tool. The lock cylinder will back out slightly.
6 - Depress the second retainer through the lock housing access hole (1) the lock will back out slightly again.
7 - Pull the lock cylinder out enough to locate the second retainer to the lock housing access hole (2).
8 - Depress the retainer through the access hole (2) a second time. The ignition cylinder should release from the housing. If not, the ignition cylinder may need to be moved in and out several times to locate the retainer correctly in the hole.
9 - Remove the lock cylinder from the lock housing.
Removal Procedure:
