I'm not sure- 6'11'' will fit in a Sky comfortably without issues, to legs/knee's
hips/back or head/neck area's of the human body. During it's original engineering
concept- I'm pretty sure this was not discussed at a round table setting of designers
or engineers, nor was it ever tested, in theory or CAD design.
I could be wrong about this .
However- the seat base track can only slide so far back, for leg room, to say nothing of
knees hitting the steering wheel, the driver's door panel or transmission tunnel.
Headroom with the top up is a forgone conclusion that this problem is not in your
best interests here. We have many owners well over 6' that sorta fit in our Sky.
Your comfort level will vary.
Top down no problem but- you might be looking over the front windshield surround
during this process. Invest in a full shield motorcycle helmet is my suggestion.
Top down only when in use stickers are available in our lobby.
Testing the power window switches on the driver's door will be another unique experience.
You might be able to have the seat base tracks surgically altered by a custom fabricator to fit
your dimensions, again I would ask first before.. you buy a Sky. IF... this is possible by cutting
into the trunk area- which is limited in space to begin with- there might a chance to drive the
Sky from the rear wheel area, but this eliminates the top assembly all together which could
solve your problem of will it fit me. Cutting the car in half and extending it by 3 feet is another
solution to look into. Check with stretch limo services for costs in your area for alterations.
Making you fit the car by making you smaller is not an option.
Stretching the car might work but I have never seen it done professionally.
It would make an interesting TV or U-Tube show for entertainment purposes.
