1 - 20 of 74 Posts
I have read the posts about this "trunk lifter", corresponded with Werner at GT-Manufaktur, (he sent the installation instructions) and I now have the assembly in hand. My car is a 2007 Solstice GXP. I don't happen to have a Sky roadster for comparison on the trunk body structure. Mounting to the trunk lid is no problem, however...nowhere is the installation of the body mount in the trunk shown. It is always shown in place, either in the instructions on on the forum. Does the Sky have two bolt holes or is it simply the open space, about the size of an old time 35mm slide. The forward facing plate with the two bolts slop around in that space until you cinch them up to the lower gas strut mount. That's what it looks like on the Solstice.
There is no mention of how to align the bottom assembly relative to that square opening so the gas strut is aligned properly. Maybe I'm asking for more information than this needs to make it work but it sure would be nice to get it right the first time. There are also no lock washers for the two bolts and until you begin to tighten them there's a bit of movement there.
I appreciate any helpful information. If you have installed one of these then you probably know what I'm talking about. Next step is for me to post photos I reckon.
Thanks,
Richard Snipes
Richard, I have helped install one of these but that area of the trunk is one of the few places on our cars that differ from Sky (Opel GT) and the Solstice. I can't remember how that goes but perhaps someone here will be able to better assist you.
I installed one on my first Sky just a couple of months ago, and it was pretty straight-forward.
I also wonder if you are running into a difference between the Sky and Solstice here.
I remember seeing that the Solstice mount is more difficult (different), but can't remember where I saw it. Search the Solstice forum - it was probably there.
Discussion Starter #6
Guys, I'll do my best to post some photos in the morning and perhaps that will clarify things. The Solstice merely has an open square the lower mount bolts go through, small plate on the trunk side and bracket on the rear side, if you will....
If the Sky has two bolt holes rather than the open square then there's the difference. Jim, the video is quite good however it does not show the lower mount bolt assembly except in the completed state. You could probably verify the mount procedure with a glance and a touch.
TS, I swear I've combed the Solsticefourm and come up empty so many times on this. The Sky guys are all over it and the seat belt guide installation. One Solstice owner did say the trunk lift works and I think it will. It's the initial slop that concerns me and the bolts backing out allowing shifting over a couple of times opening and closing. Like I said there are no lock washers and the nuts are not nylock so only thread torque is keeping this thing in alignment, at least in my observation. I so want it to work.
Thanks,
Richard Snipes
I ended up building my own based on GT Manufaktur's design.
Based on your description, the SKY is the same as the Solstice - an open square. The plates are larger than the hole and bolts are at a diagonal toward the corners of the open square, helping to keep the mounting from twisting. Each plate will 'sandwich' the bracket on either side. I just used lock washers.
Thread lock should help. I'm not sure if we used that on Jim's.
I dont recall having to use any thread lock on mine. It was your buddy visiting from Mexico that installed it for me as you may recall, during our mod day (I forget his name). As I recall though it was a slam-dunk installation and I had not realized it would be different on the Solstice. I will see if I can get better pictures/video around the mount point but I am reluctant to loosen as its working so nicely!
Ugh, **** happens. Since I need to do this to my car, figured I could run out install take lots of pics and get it done and help out. Hmm can't pop trunk, lets start car its been sitting for few months anyhow. Hmm seems to have no power, battery must have run dead.. **** key now stuck. I have no battery charger, car pulled in garage nose first not getting jumper cables in. Need to go get a jump pack to get the key out, arg if its not one thing its two others.
The purpose of this is get trunk to open fully when remote is pushed? If so, why not just a simple spring? My trunk fully opens when I hit remote. Am i missing something?
How can I order one of these ?????
Web site was German only that I saw. Help me out here.
Thanks, Larry
EDIT OK, looked around and found a post from Davhamm. Good to go just email him, wait on paypal invoice, send money , DONE.
Thanks, Larry
Yes. If a strong breeze is blowing and catches the trunk it can fling open and damage the hinges and/or trunk. This is a strut with a shock and it controls how fast the trunk opens and if the wind catches it, it will slow it and keep it from damaging the trunk. The spring won't. It also looks nice and factory.
Your trunk opens fully - right now. Over time the spring gets weaker and eventually will not open the trunk without manually assisting it.
I installed this on my first Sky (did not use Loctite, but I seem to remember that there WERE lock washers provided). I do not have it on my new Sky yet, but will probably be ordering one soon. It's a great product, I highly recommend it.
I was complaining about how my trunk lid doesn't open fully enough just last week. I had hit the popper on the remote on a windy day, and went to pull the trunk lid open and the wind caught it. I then realized that I'll be okay just lifting it up.
STILL, reading through this post made me think that I'd like it to open more fully: then I remember the incident last week. #conflicted
Thanks, Larry
Thanks, Larry
I used Google Translator on their web page and it did a reasonable enough job for me to understand the order process. I paid via Paypal and the shipment arrived faster than I expected. I can definitely assure anyone ordering from them that this company is legit and provides good, timely service :)
I agree with Robo, after fitting the gas trunk lift/piston, it definitely feels like this is how it should have been built by GM but maybe they didnt have any gas shocks in the GM parts bin when they built our Kappas!
Discussion Starter #18 (Edited)
Solstice mount space look like Sky?
If I had enough hands and arms I could hold the camera and the lower bracket in place. As it is, here's a photo of the mounting place on my Solstice for the trunk lifter. Upper bracket mounts on the two bolts on the lid hinge attaching place easily per instructions. In the photo you can see the little square opening that's been giving me concern. Well, holding the bracket up behind the brace opening has the diagonal bolt holes at opposite corners very snugly positioned so the bolts, washers and the cover plate would cinch up in alignment. I still think I'll add star lock washers for belt and suspenders effect.
I'll post again when installed. Anyone who wants to verify the Sky is the same or different, please do so. My thanks to all who've commented so far. I still want to see a Sky fitment location.
Richard Snipes
I'll post again when installed. Anyone who wants to verify the Sky is the same or different, please do so. My tanks to all who've commented so far. I still want to see a Sky fitment location.
Richard Snipes
Would love to but can't get the trunk open, trickle charge does not seem to be working, and I don't think my jumper cables are long enough and I don't have a battery pack. Somehow I will figure this out.
I got a close up of the mount point in my Sky and it seems to match you picture too. It looks like the bracket (in the red circle) is square in shape and fits in the opening from the back side. Once bolted from the front side, its shape would not let it move or twist.
1 - 20 of 74 Posts
