OK, so I got a new toy and I’m having issues with the cluster lighting. I’ve read most of the posts, but I’m throwing this out there.
I can’t get the speedo or tach lights to come on at all. Doesn’t matter what setting I’m in on the turn signal stalk.
The dimmer wheel is unresponsive.
‘If I turn the car on, the exterior lights come on but everything Inside is dark. If I go to the auto lights off setting, the radio lights and the DIC will come on.
All the exterior lights runs til as they should. headlights, taillights, brake lights, back up light and turn signals work.
Fog lights will turn on with the switch, but don’t turn off.
Doesnt matter if the car is in the garage or in the sunlight.
I went in and “re-seated all the fuses and relays to make sure none were loose.
Precious owner said all worked. I have no reason not to believe him.
low hanging fruit tells me to start with the dimmer switch, etc.
thoughts? I’m mechanical, but weak with electronics.
