1 - 3 of 3 Posts
Has anyone had this experience? It happened once, then went away. Happened a couple of more times. Now I have significant outage. Everything works fine - radio, cruise, etc - just no lighting. I've had low tires and recently pumped them and am trying to check the pressure, but no lights. Thoughts?
Thanks!
Play with the dimmer control on the dash... make sure you haven't turned it down to off. If not, tap on it and see if anything (e.g. connector) is loose.
What he said.
Also try rolling the headlight switch back to turn the auto headlights off, as this will disable the dimming control.
1 - 3 of 3 Posts
