I'm really happy with this for backup light.Finally got curious enough to look up the suggested LED via the eBay link that rjgramps provided. I hate to say it, but I don't think these bulbs are going to last very long in this application! IF the bulb has a built-in resister as they claim (big IF!), it will burn out pretty quick with no way to dissipate the heat. Also, I don't believe there is any such thing as a "5-15" volt LED?! If 5V makes it light up, then it's a 5V bulb and anything more than that is over-driving it. They say you can add an extra resistor...ok, what value?! Just beware - it's a lot of work to replace these and it would suck if they don't last.
I hope you are wrong because it would really stink if these LEDs don't last. I will find out one way or the other. So far so good but admittedly we don't drive the car on a regular basis so it will take some time to find out.I hate to say it, but I don't think these bulbs are going to last very long in this application!
IF the bulb has a built-in resistor as they claim (big IF!), it will burn out pretty quick with no way to dissipate the heat.
It's a lot of work to replace these and it would suck if they don't last.
You are the second person to post this incorrect info recently, not sure where you all are getting this from. Of course LEDs ARE dimmable by reducing forward voltage (and hence current, given a series resistor). Just look at an LED datasheet. See the extract below, second graph. Luminosity is directly (linearly) proportional to forward current.Technically, LEDs are not dimmable by reducing voltage unless they are being over-driven. The rated forward voltage is where they light up to rated output, and anything less than that might not light them at all.
This is the manufacturer's description of the LEDs referenced by @rjgramps :In that 2nd graph, Y axis (luminance) is relative to 20mA, so it's saying that at 20mA (its rated forward current), you get 1.0 rated luminance, at 10mA you get 50% less luminance, and at 30mA, you get 50% (1.5) more luminance.
This doesn't change what I said though. Technically, if you find the current that lights the LED, everything above that is overdriving it, but that doesn't mean it isn't still within the manufacturers spec. They could take the same bulb and say "lasts forever" at 10mA, or "lasts for 10 years" at 20mA. These specs tell you that if you drive it at 30mA it will put out 50% more light, but the datasheet does not suggest at all that it can be driven continuously and safely at that level (think PWM).
They state clearly that they will work at reduced brightness below 12V, down to the specified 5V.Here we have a newer style LED to the scene! We've got a 12v 3mm cool / clear white round top led. This is a special style of LED because it will on 12v with just the LED you see. It will actually work between lower voltage of about 5v to 15v. You will lose some brightness if you are using at a lower voltage than 12v, but it will still work well. If you've worked with LEDs much in the past you will be familiar that most LEDs that are around the 20mA range will only work on approximately 2-3v without a resistor, depending on the color and technical specifications. These LEDs are particularly special because they have a current limiter inside the actual lens itself. What makes these even more rare is that we have taken it a step further and designed them so they will work with voltages up to 15v. While we don't recommend running them continuously at 15v, they will be ok with occasional spikes. This is something you will definitely not find in other LEDs similar to these out there. This is particularly useful in automotive applications where the charging systems see these higher voltages. With all of this said, we still recommend using the good old fashion LED with an external resistor added in, if possible. It keeps the heat further away from the diode itself and that is always a good thing. We know this is not always possible, so we have brought the 12v 3mm cool / clear white round top LED to you for such applications. You can't go wrong with the 12v 3mm cool / clear white round top LED.
Yes, and No! An individual LED will have a forward voltage drop, depending on color, of between ~1.7V (red) and ~3.2V (white/blue). Without a built-in or external resistor, exceeding this forward voltage by more than ~20% will blow the LED in short order. HOWEVER, LED bulb assemblies often include a series resistor (and sometimes diodes or bridges) that allow them a much greater voltage supply range, given that at higher voltages, the resistor drops the voltage enough to save the LED. Some fancier LEDs even include a constant current converter allowing a much greater applied voltage range, while still applying a constant "cruising" current to the LED that allows for max life/brightness.So the question is, is there really such a thing as a 5-15V 15mA LED? I think not
Do you have a wall dimmer for that fixture? Many wall dimmers and LED bulb combinations do not work happily together, resulting in just the symptoms you describe.I don't know why, but two 25W equivalent light bulbs in a particular light fixture, blink at random.
No dimmer here, only straight 120V 100% of the time.Do you have a wall dimmer for that fixture? Many wall dimmers and LED bulb combinations do not work happily together, resulting in just the symptoms you describe.
We are talking about a specific LED here...it's not a bulb assembly but a discrete component. It claims to have an integrated resistor but doesn't specify the value, or the forward voltage - only the forward current.HOWEVER, LED bulb assemblies often include a series resistor (and sometimes diodes or bridges) that allow them a much greater voltage supply range, given that at higher voltages, the resistor drops the voltage enough to save the LED.
If it includes a resistor, then it is an assembly by definition (LED+resistor) - exactly what I was talking about. A discrete component would be an LED only.We are talking about a specific LED here...it's not a bulb assembly but a discrete component. It claims to have an integrated resistor but doesn't specify the value, or the forward voltage - only the forward current.
It does specify a forward voltage for the assembly: 5-15V, although it states that anything over 12V is not recommended for extended periods. Read the lines that I underlined in my quote from the manufacturer's specification page here: LED Interior Lighting, Bight Daylight Color Throughout...We are talking about a specific LED here...it's not a bulb assembly but a discrete component. It claims to have an integrated resistor but doesn't specify the value, or the forward voltage - only the forward current.
If I do this mod (and there's a decent chance I will), I would use standard off-the-shelf LEDs and find a way to turn the dimmer into a control for a PWM module. Here's a suitable unit on Amazon Canada for under $10 - DC 12V-14V 8A LED Bulb Dimmer Switch Brightness Controller, Dimmer Switches - Amazon Canada
