2007 Saturn Sky Redline. 5-speed, gray. 87k miles on body. 1k miles on crate engine and turbos.
I appreciate all the info, JohnnyG. There are a lot of electronic applications I have a good working knowlege of (like musical equipment, etc), but this ain't one of them. lol And I'm certainly not an electrician, either. So all help is very much appreciated.CANBUS is a data bus (network) used for signalling. After doing some thinking, I believe the reverse circuit is probably on the CANBUS since there's a reverse signal line in the stock stereo wiring harness. And since the bulb is part of that circuit, I can imagine that a non-CANBUS bulb could cause issues. However, no idea how the airbag sensor is involved?!
Regardless, I would suggest a CANBUS bulb, and something that at least claims "low RF interference" or "low EMI". I doubt you need a resister in this location so I suggest you just try that first. If it still doesn't work, then either a 3157 with CANBUS and a built-in resister, or an external resister. Built-in resister is easier, but these have a fan on them that would be inside the back-up light enclosure, and I'm not sure that this enclosure is ventilated at all, so the bulb might not last as long as it should, or may cause excessive heat build-up.
I have contacted Siriusled and Viper Lighting, and explained the problem in detail. Both have been good at communicating. I'm not worried about the 10 bucks, or so. I would even go to local auto parts store, if necessary. Right now, I'm ready to install the map, trunk and license plate LED's, but I'm not going to until I hear back from seller. I haven't heard of any problems like this for the map or trunk lights, but I'll wait for Viper to let me know for sure.
I bought the reverse 3157 LED from Siriusled, and they have offered to send me another "style", but I don't exactly know what they mean by that, so I have asked for an explanation..... As you said, if it's not a CANBUS, I'd be skeptical of accepting it as a replacement. Thanks, again.
