John is so right. The stock head bolts are also torque to yield. This means you torque them to 22 ft/lbs in sequence (tightening them in sequence is VERY important) and then tighten them another 155 degrees. This stretches the bolt. This means you can put a torque wrench on them and make sure they are at 22 ft/lbs but they could still be loose. There is no torque spec to check at this point. Once stretched, the bolts CANNOT BE REUSED. You will need to replace these bolts. There are four smaller bolts at the front of the head you can reuse as they get torqued to 22 ft/lbs and left alone.
Personally, I would get ARP head studs rather than more OEM head bolts. These studs get tightened to 90 ft/lbs (incrementally, 50 ft/lbs in sequence, 70 ft/lbs in sequence, then finally 90 ft/lbs in sequence), are reusable (if you have to do the head again they will pay for themselves as they cost about the same as the cost of two sets of OEM head bolts) and have more clamping force than the OEM bolts. I have them on my build.
You could just get the RPM big wheel K04 turbo. They get them from a reputable turbo shop who balances the shaft. If you are doing all this, rebuilding the turbo should be on your list too anyway.
As Steve can attest, DO NOT use RTV on your oil return line to turbo flange connection, use the OEM gasket. If you use RTV, it can hinder oil flow and cause the turbo to smoke.
ARP also has a bolt kit for your timing chain guides. Not sure if they are necessary, but a nice bit of insurance. I got them.
As for your boost level, you are probably maxed out but not dangerously so. Depending on where you live, 26 psi may be acceptable (if you are at a high elevation like Denver).
