1 - 3 of 3 Posts
I have an 08 Sky Redline and the heat/air blower motor is not working in any speed. Using a test light and/or multimeter, i have checked all fuses and they are good. There is ground but no power at the blower motor plug. There is ground but no power at the resistor plug. None of the plugs or wires look burnt or discolored. The readings on the multimeter do change when turning the hvac control speeds so i am assuming those are good. Please help. I am at a loss. Thanks
I'm confused... you say "no power" at those places, but then that the MM readings change when you turn the switch. What readings?
Apart from that, I would say you need to check the big-assed switch (or the connector itself) at the back of the A/C controller module.
1 - 3 of 3 Posts
