1 - 2 of 2 Posts
Hi Folks,
I was hoping someone might be able to shed a little light on a problem I'm having. After sitting all winter, the battery was low in my redline when I went to start it. I forgot to put the trickle charger on it (DOH). There was interior lights, but not enough juice to start the engine. I put the batter charger on it for a bit and when I went to get in it there was no power anywhere. I checked the fuse block int he passenger foot well (specifically fuses #8 , #25 & #26 ). I also checked the large 30 and 50 Amp fuses in the fuse block above the battery and none of them seem to be blown. Any ideas? Also, I just replaced the battery last year, so It's basically brand new. Thanks in advance everyone!
Did you test if the battery is OK? It's quite possible that it was too low for the charger to charge (some chargers will stop if the voltage they see is too low). So now the battery has just discharged the rest of the way.
1 - 2 of 2 Posts
