I am speaking here with no actual knowledge, because I have not had one apart, but I expect that once you get it out you can then take it apart. There is no description of the disassembly of the filler hose, but the illustration shows a hose clamp other than the one that holds the assembly to the tank. It appears that you can remove the lower assembly that includes the check valve from the upper assembly, at which point the flapper will be easy to remove.So, even with the fuel filler line removed, it could still be a pita to pry out that little flapper unless the flapper is too big to go thru that nipple the fuel filler line attaches to.
