1 - 13 of 13 Posts
Anyone have any pictures or diagrams to the OBD2 port in the Sky? I looked around the driver's side pedals, but it was dark and I didn't see anything.
Thanks, all.
I think, most current (2006 and up) GM vehicles the ODBII port is on the steering column with a rubber cover over it.
On the Sky, I believe, its just under the steering column if I recall..:thumbs: Most do have I believe the protective cover to prevent any kind of a possibility of a short:cheers:
Yup. Sitting in the car, you can reach it easily. It's inline with the steering column, if not physically on it. I don't feel any cover on it.
Thanks, all.
At the bottom of the dash monted under the steering column. Don't let it bite you.:jester:
Discussion Starter · #6 ·
Ok. Cool. I will look for it tomorrow. Thanks everyone.
Is a cable attached to it going to bug me while I'm driving? :)
Yes. It will be in the way.
It depends on how large the plug is. Some of the scanners have giant plugs and they could get in the way.
If the connecter is small with the cable going at a 90 it shouldn't be a problem. I have one connected all the time and have never noticed it.
Steve
In my Solstice, I have a dashhawk plugged into the port and the cable doesn't bug me. I have the cable itself tucked up under the edge of the dash trim, so it doesn't "hang down" in any way. The dashhawk itself is mounted next to the stereo controls.
Thanks, all.
Here it is...
Thanks, all.
Here it is.
Thanks, all.
Here it is
113176
Given the OP's query is 11 yrs old, he's probably found it by now and didn't need your help.
1 - 13 of 13 Posts
