Yes you are correct in subtracting the spacer width from the offset--it's going to push the wheels out farther, which is effectively a lower offset number.
Keep in mind too that with the wider wheels (10" vs 8") the offset is measured from the centerline of the wheels--so those are going to have an extra inch on each side of the mounting surface.
Hopefully someone else can chime in on the potential clearance with the fenders.
