For about the past 1.5 hours, I have been trying, without success, to reset my Oil Life Monitor (OLM) on the DIC. I have been using these instructions from the 2008 Saturn Sky Owners Manual:
How to Reset the Engine Oil Life System:
After changing the engine oil, the system must be reset:
1. Turn the ignition to ON/RUN, with the engine off.
2. Press the information and reset buttons on the
Driver Information Center (DIC) at the same
time to enter the personalization menu. See DIC
Vehicle Personalization on page 3-45.
3. Press the information button to scroll through the
available personalization menu modes until the
DIC display shows OIL-LIFE RESET.
4. Press and hold the reset button until the DIC display
shows ACKNOWLEDGED. This will tell you the
system has been reset.
5. Turn the key to LOCK/OFF.
If the CHANGE OIL SOON message comes back on
when you start your vehicle, the engine oil life system
has not reset. Repeat the reset procedure
What I have tried:
First, I thought that maybe I am not holding the buttons long enough? So I timed my hold with the stopwatch on my phone and repeated the procedure, holding for 60+ sec. No workey!
Next, I thought that maybe the engine must be run and then shut off before starting the reset. So, I started the engine and ran for 6-7 sec, and shut off, waited 60 sec, repeated the procedure. No workey.
Next, I noticed that the Cruise Control was on so, I shut off the CC and tried again. Still No workey!
I was turning the ignition key off and then back on between attempts, and I thought maybe the key needs to be off for a certain amount of time before another attempt? I shut off the ignition and timed 60 sec, and tried again. Still no workey!
I wasn't sure what should be in the DIC display when attempting a reset, so I tried starting a reset with Outside Air Temp/Odometer. No workey.
Then I scrolled the DIC to the OLM, shut off the key for 60 sec and repeated. Still no workey!
Some on the 'net say to turn on the ignition, pump the gas pedal 3 times and hold. Then the OLM "Should" reset. No dice.
Then I wondered, do I hold the pedal down on the 3rd stroke or pump one more stroke and hold? So, I tried 3+1 and hold. Nothing!
This is supposed to be so easy that "Even a Caveman can do it," Right? Not for me!
Just to be sure: The "Reset Button" is the top button on the left spoke of the steering wheel, right? It says "RES+", and the "Information Button" is the second one from the bottom which says "INFO," correct?
What am I missing? It MUST be something simple!
After all of the above attempts I was looking for the "personalization menu" to appear, but it NEVER did! That is what I meant by "No Workey."
Can ANYONE suggest ANYTHING that I am missing?? PLEASE!!??
Yogi
What I have tried:
Yogi
