nope, it is a computer calculation that takes into account the temperature, engine loading along with mileage, rpms and everything to decide when to change your oil, it could be as low as 3,000 miles or as high as 12,000....1994SC2 said:So does that mean the DIC oil life meter is just set to a timer/milage amount?
Thank you SkyMan!SkyMan 07 said:nope, it is a computer calculation that takes into account the temperature, engine loading along with mileage, rpms and everything to decide when to change your oil, it could be as low as 3,000 miles or as high as 12,000....
i usually get ming changed at 50 to 60 percent on the monitor...
Why so soon? the Owners Manual recommends <20% (or when it tells you)...SkyMan 07 said:nope, it is a computer calculation that takes into account the temperature, engine loading along with mileage, rpms and everything to decide when to change your oil, it could be as low as 3,000 miles or as high as 12,000....
I haven't tried it yet so I can't be sure, but the owners manual says nothing about pushing the gas pedel 3 times.Kustomkaps said:Just had the oil changed today. To reset the 'oil life' read out you first turn the key so the control panels light up, scroll down through the read outs to the "oil Life" line, then push the gas pedel down 3 times and hold it. The "oil life" reading will go back to 100%. Just saw the tech do it today.
Had my oil changed today. Kustomkaps is right. Key on, engine off, push gas to the floor 3 times. The instructions in the owners manual also work.I haven't tried it yet so I can't be sure, but the owners manual says nothing about pushing the gas pedel 3 times.
Yes, you press the pedal 3 times. This is inside info that we don't usually tell people. You teckkies are on the ball!I haven't tried it yet so I can't be sure, but the owners manual says nothing about pushing the gas pedel 3 times.
I pressed the gas pedal to the floor three times, and then held it, and the speedometer read 134 when the officer pulled me over. Do you think the judge will buy the fact that I was just resetting my oil life indicator?:nono:push the gas pedel down 3 times and hold it.
Key on, engine off.I pressed the gas pedal to the floor three times, and then held it, and the speedometer read 134 when the officer pulled me over. Do you think the judge will buy the fact that I was just resetting my oil life indicator?:nono:
