1 - 10 of 10 Posts
Good morning
I have an 08 Redline. Last week after plugging the brakes to avoid a deer, my cat started to overheat. Not sure plugging the breaks has any correlation to overheating, but after this is when it occurred.
I read through all the posts on changing the thermostat, burping the coolant system etc. So I am mechanically inclined and decided to change the thermostat and coolant and went through all the steps. Probably 3X on the burping. No luck.
I even bought the fluid transfer pump and did that today. No luck.
I also purchased the purge valves and installed both per the tech document.
As I drive the temperature seems to drop a bit and stabilize, but if I coast the temp increases. And of course there is still no heat. And is going to get cold in PA really soon...
I noticed when I returned from the drive today the temp was about 251, and the reservoir was completely full and coolant was coming out the overflow. Within a matter of minutes, it purged and the level returned to normal.
Questions I have.
Still air in the system?
Should I bring it to the dealer for a vac and fill for the coolant?
Faulty thermostat ? (Just replaced)
Water pump?
Anyone know any good mechanics in the Scranton/Wilkes Barre Pennsylvania area ? I'm sure I will get raped by the local dealer and may end up the same place I am now.
Thanks in advance
Questions I have.
From that symptom, YES!
Try burping it again, and/or buy your own pump. Doubt it's the thermostat or water pump. The latter would be indicated if you saw leaks or overall lowering in coolant level.
Good morning
Questions I have.
Water pump?
Thanks in advance
Disclaimer: I am a new mechanic and still learning.
I recently changed my WP and Thermostat. Burping took patience.
As soon as I return from my family emergency out of state trip, I'm going to be slapping in all new DDM hoses... which means burping it again.
What I did the first time (and seemed to work with MANY cycles):
1) Had the drivers side of the car as the highest point.
2) Had my friend hold the reservoir as high as the car would allow.
3) Filled from the radiator hose.
4) Took the relief/return hose off of the top (header???), and kept going through cycles until it pumped out like a steady geyser.
5) Turned it off as soon as I hit 212 (probably too conservative and why I had to do so many cycles).
What I plan on trying next time:
1) Using air hose pressure to push fluid through the system (per the Tim Ronak video)
Is curious you mentioned that about the deer.
my overheating problem appeared some minutes after I raise the car in a new ramps with some abrubt movements That probably created the coolant moved in the reservoir tank so much that maybe in a concret moment some air could introduced in the circuit.
i dont know if this is a Stupid idea but I have been thinking about that and now, after read this message it make me think about this relation again
in other hand, if this happens, all the people that goes to the circuit on track days would suffer this problem and I don’t think is the case so..... no idea
Discussion Starter · #5 ·
As I said, there is probably zero correlation between me plugging the brakes and my issue. BUT, I am trying to cover everything. I also just noticed a leak under the DS. It could simply be blowing out the overflow, or something worse. I see nothing leaking at idle. This is a real pain..
Discussion Starter · #6 ·
Good morning
Questions I have.
Water pump?
Thanks in advance
UPDATE #1
So I tried everything.. Had the car towed to the dealer. They are telling me the water pump drive chain is not working, thus not providing the pump to turn and move coolant..
They sent me an estimate. The fee was $125.00 per hour for service.. Would cost over 2K to fix and they were not even changing the water pump out. I told them I was picking it up and I ordered the parts separately.
Questions:
Anyone ever change the water pump drive chain?
Where is it even located?
Are there any instructions located anywhere?
Any help would be greatly appreciated..
I am the last one you should trust on, due I Am new with this car, but just suffered same problem. The chain tensioner was broken and the chain loosen.
take a look to this in case it helps
1 - 10 of 10 Posts
