I'm new to the Sky forum, and had to sort through a lot of information to get an idea of what improvements are available. Here I will try to build a short and sweet list of options. The early major lifting is thanks to @Robotech
Here's the Excel sheet
It's a live document I'll be updating as I go.
I'm adding replacement parts too.
Be sure to check each tab.
Please feel free to add in the comments to contribute!
Edit: I'm having a lot of fun doing this... The price disparities between shops is amazing (e.g. $300 price difference between shops for connecting rods).
Edit 2: Summit Racing has so many replacement parts. Redline has a lot of OEM parts pulled from Sky's. ZZ has a great upgrade selection, and has quickly become my favorite LNF supplier. Amazon has a surprising selection of parts. There are so many, I doubt I'll be able to collect them all in the document.
Edit 3: There are an insane number of gaskets. Just Google the gasket you need. Also, it's slim picking for exhausts.
Edit 4: The sheet now has a lot better organization and load of replacement/ exterior/ interior parts. It is far closer to its final form. I'll be updating it a lot less frequently (I've combed through a lot of shop pages in the last 18 hours).
The main vendors for our platform:
DDMWorks - Research. Design. Driven.
Summit Racing
Performance Autowerks (also referred to as PAW)
RPM Motorsports
ZZ Performance
Redline Autoparts
Hahn Racecraft
Amazon
These are some of the options available:
Summit Racing
RPM Motorsports
ZZ Performance
Redline Autoparts
Hahn Racecraft
Amazon
- Radiator
- Rear Brace
- Front Brace
- Backbone Brace
- Cold Air Intake
- Bigger Turbo
- Intercoolers
- Charge Pipes
- High flow cat or catless downpipes
- Catback Exhausts
- Coil Overs
- Sway Bars
- Front, Rear, Middle chassis and suspension arm braces
- Limited Slip Diff
- Clutches and Flywheels
- Injectors
- Extra injectors
- Cams
- Fuel pumps, both in tank and high pressure
- Forged Pistons
- Forged Rods (engine already has forged crank)
- Intake Manifolds
- Dash trim
- Big brake kits
- Larger brake rotors and better brake pads
- Larger Valves
- Heavier Valve Springs
- Lighter Titanium Valve Retainers
- ARP hardware for head and timing chain
- ARP wheel studs
- Carbon Fiber D-shaped custom steering wheels
- Headlight and Tail light eyelids
- Driver's pillar gauge cluster
