I'm trying to source down what my issue is and what the solutions would be.
Background:
Sky Redline with 73K miles. Water pump failed a few months ago. I replaced the water pump and a bunch of the coolant hoses with new ones.
Issues:
What I've tried:
- Found I hadn't tightened two hoses down as much as I should. Tightened them, cleaned up any residue, and yet I still get the coolant smell.
My thoughts so far:
I originally thought it was some loose hose I couldn't find and a rear main seal leak.
Now I'm wondering if it could be a leaky oil cooler...
Thoughts and suggestions are most welcome!
Background:
Issues:
- I get a slight coolant smell when the engine is up to temp and stopped at a light.
- There is an ever so small oil leak coming down the seam between the engine and the transmission.
- There looks like there may be a very small amount of oil in the coolant reservoir.
What I've tried:
My thoughts so far:
