So I have a 2008 Sky Redline 2.0 with about 82k. I came out to the garage this morning to head into work and saw the reddish-hued puddle / trail coming from underneath the car. It was a pretty good amount. From what I can see, it's coming down around the center of the engine and after opening the hood, I could see some of the same liquid puddled a bit underneath the water pump, so I'm pretty certain that's where it's come from. The resevoir is about 1.5-2" below the mold line, too. I've already made an arrangement with my dealership to get it looked at tomorrow by someone who also owns a Sky (in fact, he was one of Saturn's master techs, thank god!). I still have to drive her into the shop, though, which is worrisome. I only have to drive about 21 miles in, so surely I can make that, but to be sure I have enough coolant for the journey, I'm at a loss as to which coolant I should buy at my local O'Reilly or AutoZone.
Since my coolant appears to have a very light reddish hue to it, I'm not sure what I should do if all I see from my stores is yellow and orange. If I buy one of the premixed versions of orange and top off with that, will that blow anything up for 21 miles worth of driving? I figure if they change the water pump, they'll do a drain of what's in the engine anyway, so I'd hate to think it would matter that much for 21 miles. If it gets above 220 degrees, I'll just pull over and make sure it has some in the resevoir, but I really want to avoid having her towed if possible because I have some ground effects that I just know would get screwed up if she ever had to be towed.
This is the coolant I was planning on getting today: Advance Auto Parts - Down for Maintenance
